Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
a.king21
Quote from: citfta on July 31, 2019, 06:44:16 AM
I only see 11 leds being lit.  I agree there are probably 50 coils but most of them don't seem to be connected to anything.  So the claim of lighting 50 leds doesn't seem to be correct.
Carroll
Again an assumption without any facts.  If you could be BOTHERED to go to the video, Rick disconnects his camera and does closeups on the coils so you can see the leds lit.
And here is another fact. Rick's leds are much dimmer than comparable leds, which is why I swapped them for superbright leds.
However Rick's leds are more durable.  I have only lost one of Rick's leds but several superbright ones.  If you make a supposedly scientific comment then you should double check your science or you do not come over as credible.
Chet,I allow in my calculation a battery/capacitor for the " starting 'kick'", because actually battery and charger and con-/inverter makes such continous use systems to expensive. !
Motor and transformer need also for the first process beginning cycles high current draw :without "inrush current limiter" - up to 20 times the nominal current value
Aliernatively the ancient ic-mobile starting device : hand-curbe
a.king21
Stefan: the notion of batteries in the circuit is an important one.  If you go to Rick's video on the Heavyside component he
explains the science there.  And again it is a secret revealed.
The use of capacitors as comparable (as some experimenters have done) is just ignorance of the experimenter who knows nothing about this ou science.
When it coms to capacitors there is much experimentation to be done.  For example reforming capacitors and conditioning them ( and conditioning batteries) is an important aspect of this science.
Quote from: rickfriedrich on July 31, 2019, 02:15:55 AM
Nice red herring fallacy.
How can an image of YOUR POSTS be a "fallacy"?  Seek help, Rick.
Meanwhile, either demonstrate the truth of this claim, or admit that it is false:
Quote from: a.king21 on July 31, 2019, 08:19:06 AM
The use of capacitors as comparable is just ignorance of the experimenter who knows nothing about this ou science.
When it coms to capacitors there is much experimentation to be done.  For example reforming capacitors and conditioning them  and conditioning batteries is an important aspect of this science.
My hope for the future is that these developments
https://www.electronicsweekly.com/news/research-news/battery-lasts-200000-cycles-2016-05/
and /or
https://memoori.com/biosolar-announces-disruptive-super-battery-54-per-kwh/
will become fast (+- 5 years) available on market by fair prices !
50000 cycles/ 1 charge cycle per day : 137 years
                          4                                            34
54 US$/50000 cycles : 0,0011 US$  per cycle or 0,12 cent/cycle
54 US$ : production price or  fob factory     consumer price?
Alvin Marks calculated his Quantum Energy Storage with < 25 US$ / KW market price (1997)
https://worldwide.espacenet.com/publicationDetails/description?CC=US&NR=6501093B1&KC=B1&FT=D&ND=3&date=20021231&DB=EPODOC&locale=en_EP#
Referring in citing documents : http://capacitorsciences.com/
https://www.google.com/url?q=https://www.bollore.com/bollo-content/uploads/2018/01/09-28-16-bluesolutions-capacitorsciences-uk.pdf&sa=U&ved=0ahUKEwiVlZSmnt_jAhVJcBQKHfQRDr44ChAWCBUwBA&usg=AOvVaw3ekmTeNeUSSYiAHIkHo1yr
https://www.scienceandtechnologyresearchnews.com/newly-devised-static-negative-capacitor-could-improve-computing/
