Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
benfr
Quote from: itsu on April 30, 2019, 11:30:41 AM
Gyula,
concerning your writing in this post above, what would be the preferred setup for the coils, vertical like in the
below picture or horizontal which i understand from Rick's video?
Planning to drive the center coil (transmitter coil) directly from my FG (initially) with a 47pF series cap. and
the 5 receiver coils each with a 100pF series trimmer cap. to the by you suggested FWBR, 220uF puffer cap and a good known resistor.
Itsu
Immmmmm..pressive itsu ! Looks like the real beast, almost.
It's good to try and learn. just beware not to touch the coils at any time, in case you spot it right in the first place.
You would like to save you 100's hours by just buying Rick Friedrich's "Don Smith Magnetic Resonance Systematic Index". It has all what you need to replicate a  Don Smith #2. With the kit, also , by the way, if you buy 2 extra coils (same price total). Personally...I have both and I have already stated how valuable this cake is. Make yourself a favor !!! ;D
gyulasun
Hi Itsu,
I think you can stay with the vertical positions as shown in your photo.  Of course no need to fix mechanically the receiver coils, they need to be movable for adjusting coupling.  Many thanks for taking the efforts!
Gyula
a.king21
Gyula,
Itsu
A couple of points.
A gate driver increases the output massively -  The one recommended is MIC4452YN DRIVER, MOSFET, 12A-PEAK, LOW SIDE.
Not sure why your satellite coils are joined together.  The transmitter should be on the inside which it is.
Your setup actually looks quite brilliant - and is a great basis for making more receiver coils which can be placed directly behind the other receiver coils.  The theory is that each receiver coil will also become magnetically locked to the main transmitter and each receiver coil will re-transmit the signal MAGNETICALLY.(ie Heaviside component - NOT Poynting or Lorenz which is the basis for Kirchhoff's laws.)
The maximum voltage for the gate driver is 9 volts at the over 1mhz frequency range.
If you build the bigger coil it is harder to tune but is at a lower frequency and the gate driver can go up to 18 volts. If you want to build
the bigger coil pm me and I will give you the specs. (You also need 5nf caps in parallel with each receiver coil.)The output for the bigger coil is also massively increased ie 3.75 watts input gives a Heaviside magnetic output equivalent to 900 watts according to the information I  have been given. (I have not replicated it).
Grumage
Hi All.
Despite adding a comment regarding my edit of  a.king21 last post it didn't register.
Mr  a.king21 had managed to place Itsu's " Quote "  after his own making a complete " Blue " post, this has now been corrected.
Cheers Grum.
forest
gyulasun
Please read few times this little fragment of Tesla interview. There is something weird which is overlooked easily...or my English is very bad and I didn't understood what Tesla said.
