Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
tinman
Quote from: Grumage on November 13, 2017, 11:39:03 AM
Hi Guys.
Cheers Graham.
QuoteIndeed, as I see it there's no need for a rectifier if all poles are the same.
Regardless if all poles are the same or not,you still get an AC current and voltage output from the coils.
QuoteOn another point. If Mild Steel bolts were used as core material they would get partially magnetised. ( holding their own magnetic field )
Yes they do,and this drops the efficiency of the coils output,as it bias's the core to the same field that the magnet is trying to induce into it.
Years of bench testing has shown that you want the coil firing the opposite field to that of the magnet. So,if you have all north facing out of the rotor,you want the coil pulsing a south field,which means that it is in attraction mode--not repulsion mode as stated by JB.
If the coil is pulsing a north field out,you want all magnets on the rotor with there south field out.
The worst possible combination is with the magnets facing north out,and the coil also pulsing a north field out,and visa versa with south fields-->attraction mode is the most efficient.
QuoteCan anyone verify that the coils were Bifilar wound, pretty sure I read this somewhere?
I have just finished reading the PDF,along with many other references to this machine,and no where is there mention of bifi wound coils.
Also,no where in any of the PDF,schematics provided by JB him self,or any other source,dose it state that the energizer has a motoring action,or at any time is it in series with the motor and batteries.
It is clearly stated in all the information gathered so far,that the motor is !!disconnected!! from the battery when the energy from the caps is dumped into the battery.
There is no FWBR in Johns schematic shown,because each coil has it's own FWBR,which is on the coil it self.
Jim Watsons machine had 7 ring magnets,and 8 coils,where as Johns machine had 6 coils,and 6 magnets--with no offset between the magnets and coils.
Brad
tinman
Quote from: Erfinder on November 13, 2017, 09:00:17 AM
Brad.......Brad....  it's a special magneto....  just because you say it's not doesn't mean it isn't!  Here's the best part, his way is "the" way, a lesson was to be learned, you are passing up on an opprotunity....   your years with pulse motors using like poles should have prepared you.....they didn't.....  instead of revisiting what you may have missed, you now and then insist that the inventor was an idiot, and proceed to perfect that which you obviously don't get..... comprehending nothing....  I know this because I made the same mistake!
https://www.youtube.com/watch?v=WzJm0ZyPMps
david1969sulivan
This guy has a few vids and this one in particular he just made is interesting:
https://www.youtube.com/watch?v=UoE6xzYnw0s
tinman
Quote from: Erfinder on November 14, 2017, 03:06:50 AM
What amazes me is that you know....  What saddens me is that you don't know you do....  it's like I said before, your years of experience with like pole systems were supposed to prepare you for what we are discussing right now, this video reveals your lack of knowledge, it doesn't help your case.
I had a wonderful exchange with Mags a few days ago, among other things, we discussed the significance of the a principle you demonstrate but don't comprehend (not going to tell you what, but if he watches your video, a few words from me and he will know exactly what I am referring to).  It blows my mind, watching you perform the experiment, and fail to comprehend its significance....
On another note...  the magneto is a motor....  the fact that you cannot see this is a sign that you are winging this whole thing....  The years you spent bashing and correcting John while using concepts he inspired would have been better spent in silent contemplation and reflection on what was being provided....  had you gone that route, you would see more than you do....  I will share proof from the horse's mouth that the magneto is a motor with Mags.....  no point sharing that info with you...
Mags.....where are ya....we need to talk....
Cool
With all this wonderful insight,and your willingness to share with Mag's,you 2 should have a self runner in no time flat
I mean,how many times have we heard the same old thing?
How many claim that those that try,and dont see the results promised,are doing it wrong--they just dont understand,and thats why they fail.
How many times have we !not! seen a self running machine from those that accuse others of not knowing what they are doing?.
How many devices have been presented by those that say they know it all,that actually work as claimed?
I will tell you how many--None,nada,zip.
Not one single self running,self charging device has ever been presented by anyone (including you) ,that can self run ,and self charge the run battery to a higher energy content than what it started with-->NOT ONE.
You may keep playing as much as you like with what !you! think is correct,and i will keep using my equipment to see what is truth right there on my bench.
Yes,you can show Mag's what you !want! him to see--but you will never show the device as a whole,nor will you show anyone how it work as claimed.
No point in showing a wheel being spun at a slow speed,charging a cap to 1000 v in half a turn,while keeping the rest of the setup under covers--we can all do that.
So,i'll stick to what i see before me,and you keep on doing what your doing.
Remember-->those that claim others have it wrong,are the very same people that have nothing to show for them self-->sad.but true.
Brad
tinman
Quote from: Erfinder on November 14, 2017, 04:36:44 AM
What did I say....only the ignorant chase OU.....
you don't hear me saying anything about OU.....you on the other hand...  don't worry your pretty little head about what I am sharing with Mags.....  he will see what you can't, he will know what you don't... you have no idea how refreshing it is to be able to sit through your presentation and know that you have no idea what you're talking about, even better than this is when you can point out the flaws, and share these insights with a like mind is its own reward...
So lets put it to the test--your insight,your knowledge.
Lets say that i now have my machine up and running,with the generator i chose to use.
We get the machine up to running speed,and then we switch over to the circuit below.
What happens next ?
