Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
0 Members and 31 Guests are viewing this topic.
popolibero
Hi Hoppy,
yes sorry, yours wasn't a question. It came from your statement:
Towards the end of those cult years, John made an astounding admission, that all our battery 'spiking' with energisers without the use of cap pulsers, was damaging our batteries!!. I'd had enough of it by then and moved into what has become a new cult - Kapanadze free energy devices.
Unless I missed it I felt Rick didn't really address this issue, as it's part of the things that need to be clarified, in my opinion.
cheers,
Mario
gyulasun
A.king21,
Please would you clarify a few things:
1) Is the 17V DC an unloaded voltage your DMM measured across the output of the bridge rectifier?
2) where and how did you exactly measure the 9 mA? (Between which two points did you connect the ampermeter
    and you got the 9 mA?)
3) Did you check the DC voltage across the LED with your DMM voltmeter? (I mean the LED that you referred to
    and did not blow. Is it a 12V, 3 or 4 W LED bulb or the smaller sized 5-10 mm OD white LED?)
I would continue commenting after your answers.
Gyula
a.king21
The reason I mentioned the experiment is so that others can replicate.  It is not enough for me to state what I did. Others with better measuring techniques can do the experiment.  The led is a 5 mm. I measured the output of the bridge rectifier. I knew there was some power there because of the tongue test.  The output was an ordinary 12 volt 4 watt bulb not lit to full brightness. Also the gate driver battery voltage went up from 10.05 to 10.08 volts when I connected the bridge to the gate driver battery.
Afterwards I disconnected the gate driver but left the freq gen on and it continued to charge the gate driver battery, so I ended up with the gate driver battery powering at 10.10 volts before I finished the test! ( Obviously charged by the freq gen).  I hope!  ie I redid the experiment to see if the battery kept at 10.10 volts under load - which it did. My set up is at 137 khz so I can access the cheaper frequency generators although I have a tap at 180 khz.  The device goes out of tune quickly so you need the extra tuning devices like internal ferrite rods. So it was being tuned and re-tuned between 135 khz and 142 khz. The gate driver can easily go to 18 volts at these frequencies so the experiment was very under powered.  The main point is I have established a new experiment  which may open up the way for a self runner.
Hoppy
Quote from: popolibero on June 23, 2019, 05:17:04 AM
Hi Hoppy,
cheers,
Mario
OK understood. I agree that the 'spiking' issue needs clarification.
a.king21
A further point.  I replaced Rick's led with superbright leds for a better visual effect. The red leds with the kit are brilliant although I have blown one of them.  But then I abuse every component to get the maximum out of the experiment.
