Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
ramset
Erfinder
investor contacts
please embellish us with that info ?? please don't hold back !!
you have my written permission to post all you know here about that statement
I am most curious...
a statement  like that cannot go unanswered at an open source forum
and the fact is all I do is build, I just do not like wasting resources here or anywhere else.
Chet Kremens
Thanks Grandma
ramset
Erfinder
exactly
there is no info to back up your statement about audiences with my investment contacts !
there are none and never have been
what has taken place in the past .[By Dr.Steven Jones Group]
inventors who make claims of 0U have been offered Donations to open source from
Angel donors with no strings or investment attached.
open sourcing is the only criteria.
no investors
   no patents
Donors
Open source
[Key words]
Thanks Grandma
Void
Quote from: vasik041 on November 14, 2017, 11:52:13 AM
It is not a self runner, but it could be scaled up.
No big effort or investment needed, just a few hours of time and some parts from junk...
Perhaps somebody want try it :)
With one core you get 50 micro watts, with 10 or 20 core you probably can blink a LED...
Hi vasik041. If it is not a self runner, then unless you can explain here in brief and simple terms
what specifically makes you think it is OU, and briefly how you have measured the input power versus
the output power, then it will be hard for people to assess. People may not want to spend time
reading through a long PDF file if they don't even know first what it is you are claiming it does
that is unusual.
I have found that testing at really low power levels will always leave way too much room for the
possibility of measurement error and oversights. If it is not a self runner, then most likely it would
need to be producing a clear and significantly much larger output power than the input power to
generate much interest. Unfortunately really low power setups have just too much potential to show
misleading results unless you can get it self running.
ramset
Erfinder
I haven't asked you and your investor contacts for an audience,
end quote
whats to read into ??
its a false, purposely misleading  statement .
Others who seek investors for business find this "Donor" idea suspicious.
I build things for children with disabilities [not toys]
to help them and their families cope with the hardship of their daily lives.
we all do what we can to help our fellow man.
and yes I have built here and elsewhere over the years ,its hard to put down one set of tools
and pick up another when the need is soo great .
its not all about "investor's" there really are good people out there
that just want to make a difference and "give" to the right cause .
these are the Donor's which Dr.Jones has contacted in the past.
a reminder this is an open source forum.
and I would sooner hack a limb off than get in-between a life saving tech
and the world that needs it
with a price tag...
EDIT
to comment below
its just the truth
and you provoked this ... and assume way too much.
Thanks Grandma
Void
Ramset, Tinman:
Is this going to be just another thread overrun by trolling and insults like many other threads, or what? ;)
You always have to draw the line somewhere in this world regarding *all* matters. If someone
is disrupting things, then something needs to be done or it will likely only continue or get worse. ;)
If someone obviously doesn't have a clue about how to communicate in a civil manner, then whether it is
in a work place or a library or a court of law or in a family household or in some sort of discussion forum, you
just have to draw the line somewhere and do something concrete about it when the line is crossed. Otherwise
chaos is the only likely result. ;D
I realize that disruptive behavior and constantly throwing out insults etc., is the mentality level of many people in
this world, but that doesn't mean you have to put up with that sort of ignorant behaviour here. ;D
It doesn't matter at all if that person potentially has something useful to add. If they are constantly disrupting
things and throwing out insults, then obviously something needs to be done. There typically is just no reasoning
with people who are that ignorant/troubled, so in such a case something needs to be done.  Otherwise, there is a a good
chance that many who are interested in some serious exchange of knowledge and ideas here will quickly move on...
I am personally not interested in building motor/generator setups myself, as it is not my thing, but I am quite
interested in what the key working principles are supposed to be behind them which are supposed to lead to the 'OU results',
and whether they can be shown to actually 'work' in practice. If it works in a motor/generator setup, then I think
there is at least a possibility that the same principles might be put to use in a complete solid state setup as well.
This is why I have personally been following along with this discussion about Bedini's motor/generator setups so far.
Let's please stick to discussing the topic at hand, and if one or more people are disrupting things and won't take
the hint to cut it out, then simply do something about it... ;D
