Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
0 Members and 28 Guests are viewing this topic.
a.king21
Quote from: AlienGrey on July 01, 2019, 09:04:35 AM
BEWARE: Stop using the abbreviation 'LOL,'" the hastily made image that invokes the same qualities as a Westboro Baptist Church sign reads. "'LOL stands for 'Lucifer our Lord.' Satanists end their prayers by saying Lucifer our Lord,' in short, "LOL.' Every time you type 'LOL' you are endorsing Satan."26 Nov 2012
I thought it meant laugh out loud.  Ah well you live and learn.
Anyhow I did not use capitals.. I was trying to introduce some lightness into the study.
So maybe use ha ha ha instead  (ha ha). :D
a.king21
Quote from: seaad on July 01, 2019, 07:10:00 AM
quote a.king21 Posts: 1481:  Coils at all angles.             ha ha lol
It doesn't matter what you are doing guys the LEDs will be glowing anyhow.  Ha ha
Any serious measurements?
NO
Arne
The OU reference is for Overunity.com.  I never claimed anything in that picture just the fact that the coils can be magnetically crafted to light up at whatever angle you wish.  Some people may not be aware of that.  Why don't you do some experiments and show us your results instead of having a go at other people.
I could easily take your position but it's not in my nature.
That is why Rick is not going to give you much more.
Think about it....
itsu
Quote from: gyulasun on July 01, 2019, 06:39:24 AM
Hi Itsu,
Thanks for your kind efforts. Hopefully the sensor can cope with the 180 kHz frequency.
Perhaps the following suggestion may also reveal the field strength at the place where the two vertically stacked
satellite coils were positioned. See attached picture from your earlier video. First replace (in any one of the 3 coils)
the power LED bulb with a single low power white or red 5 or 10 mm LED which are able to give visiable light at
a few mW received power at the same distance from the TX coil the stacked coils were. This way you can use the
same sized satellite coil as a probe sensor coil.
I drew a vertical green line in the top picture where the stacked coils were,  remove them and then use the probe
sensor coil alongside the vertical line, up and down to indicate field strength. For this to happen you need to drive
the TX coil in the same way as earlier with the stacked coils setup and leave the 1st coil (with its power LED too)
at the same place it was when you stacked the two other coils and place the middle coil far away from the setup.
I drew a nearly horizontal green line in the bottom picture to indicate that the 3 satellite coils were positioned quasi at
the middle height of the TX coil where supposedly the EM field is the strongest with respect to the top or bottom part
of the TX coil. This may mean that when you put the middle coil onto the top of the outermost coil and the LED got lit
on the latter coil, then the top coil may not have received more energy from the TX coil because the EM field may not
have been so strong for it at that height wrt the TX coil.  This is a speculation of course.
Gyula
Gyula,
thanks for the proposed actionplan to find out why the 3th coil led went on with the 2th coil ontop.
I tried to followed it, but can say upfront that the fact that the ontop coil receives more RF is not the (whole) reason.
The main reason i think is the fact that when coupling 2 satellite coils so closely their resonance point splits into
2 different resonance points a few tenths KHz away from each other as we did see in my FG/scope tests.
I was running the FG at 180KHz up till now, but the recent FG/scope tests also showed that the real resonance
frequency of my satellite coils is around 193KHz.
So when driving and tuning the big coil at 180KHz, the satellite coils are receiving that RF, but are not quite
in resonance (193Khz, so 13kHz to high).
When now coupling 2 satellite coils we see that their resonance points split, one higher in frequency, one lower.
This new lower resonance frequency peak of the satellite coils probably now just hit 180Khz when ontop, so therefor is now able to light the led.
I checked this out by upping the big coil input frequency to 193KHz and tuning accordingly into resonance.
Now this effect of lighting the 3th coil led with the 2th coil ontop was gone, and even caused the leds to go off
because of these split resonance points during overcoupling.
Video here (rather long, sorry):  https://www.youtube.com/watch?v=pbE6YqbMJ4A
Itsu
a.king21
https://www.youtube.com/watch?v=XkAMNFKjds4&feature=youtu.be
The Moron level continued (ha ha).
Moron level of comprehension: (Don Smith)
(As per Benitez in 1914)
This stuff is only a hundred years old.
The device can be used to charge any number of other devices without discharging itself...
7 minutes in.
