Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
synchro1
This is the final finished design. The "Latching Reed Switches" alternate; The trigger magnets are N.S.N.S. The power on time is 5 seconds; 1 second for the masking pulse, 1 second for BEMF cleansing followed by 3 seconds of output. Both NOTC Timer Relays are activated and deactivated simultaneously by the alternating Reed Switches.
This setup delivers a constant series of cycles with no lapse at .05 Hertz.
synchro1
Here's a look at the carousel commutator latching the alternating reed switches. Still some fine tuning left. Next comes the timer relays:
https://www.youtube.com/watch?v=vpX2RGpEKh4
synchro1
Kinetic Art.
Happy new year folks. What's the value of kinetic art? This is a philosophical quandary.I'm sitting here staring at this contraption I wandered into and realized I could wire a 555 on a bread board to do the same work in under an hour. Thinking more on it I realized I already purchased a third timer relay that has the 555 circuit, so the commutator is just more crap for the junk box.
I caught myself by the tail again.
"Kinetic art - art that depends on movement for its effects - has its origins in the Dadaist and Constructivist movements that emerged in the 1910s. It flourished into a lively avant-garde trend following the landmark exhibition Le Mouvement  at Galerie Denise Rene in Paris in 1955, after which it attracted a wide international following".
synchro1
This video is interesting because it has the potential to generate power in the jouncing coil: The permanent magnet field is passing through the AA battery and magnetizing the positive nipple of the battery with a negative polarity. The tail end of the copper coil is grounded through the magnet discs at the base. The battery is channeling a permanent magnet field and the permanent magnets are conducting electrical current. This is an ingeneous setup. Remember Hob's principles. Lengthening the coil would increase the coil's magnetic field for the same input! This coil should illuminate an LED as a flyback transformer.
https://www.youtube.com/watch?v=o8VxPNwRuxA
