Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
synchro1
What happens when the current's interrupted? The magnetic polarity of the EM metallic casing can either hinder or assist the new current that's generated inside the EM coil depending on it's polarity and the EM connection. In the "Assisting Polarity" the new backspike current exceeds the input and instantly replenishes the power source!
shylo
In the video you ran for~ 2min.
Have you done any extended runs?
Also what is an em coil?
Thanks artv
synchro1
Quote from: shylo on February 09, 2020, 05:50:49 AM
Thanks artv
Firstly, an EM coil is an "Electro Magnet" coil. I have lot's of videos, but the power of that oscillator charger is the equivalent of a plug in model.
synchro1
"The characteristics of the spark channel plasma formed in the external longitudinal magnetic field are studied experimentally. In experiment, the current-voltage, optical, and spectral characteristics of the discharge were measured and analyzed. Synchronization of the pulsed electric and magnetic fields was performed. The effect of the magnetic field on the radial expansion of the spark channel, the shock wave formation, as well as the changes in the balance of energy and temperature in the ionized plasma of the high-pressure gas discharge were analyzed. It was found out that, in the strong longitudinal magnetic field, the temperatures of electrons and ions in the spark channel become equal. The current density, the plasma channel conductivity of the spark channel, and the specific energy deposition into the discharge increased. The channel plasma parameters were analyzed as functions of the external magnetic field".
A schematic of what a spark amplification looks like under secondary field amplification:
synchro1
This MOSFET driven neutralization pulse oscillator is in Adam's Resonance and over unity. The reverse polarity "Backspike" attracts the magnet biased ferrite ring back to the coil: There is no physical contact between any surfaces.
Backing Neo magnets in the video help amplify the flyback.
https://www.youtube.com/watch?v=gH7UW8MmC4c
The elastic suspended ferrite is stretched by it's magnetic attraction to the metal electro-magnet case below. The pulse neutralizes the attraction with a repulsive polarity, then the reverse polarity backspike creates an Adams attraction. The attraction caused by the polarity reversal appears to be supplying more power to the oscillator then the primary pulse!
Coupled with the recovery of the reverse current, the COP measures as OU.
