The secret to Overunity
Started by Tajerek, December 17, 2017, 07:40:33 AM
AlienGrey
Thank you for your reply, I beg to consider your true direction if your not 'The Secret Of Overunity'  ;D ;D
and before you misquote me how are others quotes on the internet mine ? and how do you know if they are failures or not, you don't really know, control and conjecture is just a trip down the rabbit hole.
I will say good day to you and not bother you again.
mikemongo
Quote from: Erfinder on January 13, 2018, 11:38:19 AM
as to what, the reactive cross section of the system....  as to why, to be introduced to the inner workings of the mechanism behind opposition to change....
Delay the flow of output current until it can aid the input current is how I am seeing this.
evostars
recycling of energy.
put a current into a magnetic coil.
create resonance in a parallel coil.
capture the back emf of the magnetic coil into a capacitor.
Buffer the stored back emf until the right phase angle,
and reinsert the back emf from the capacitor into the resonant coil.
The coil becomes even more resonant (higher voltage).
The resonant coil is coupled to the magnetic coil.
This creates a feedback loop.
A second resonant coil is resonant with the first resonant coil.
rectify the high frequency second coil for output.
Magnetic coupling is slave to Lenz law.
Electric field coupling is not.
sm0ky2
Take the 3rd phase of a commercially engineered motor/generator
Reverse it, use it as a capacitor
you sacrifice 1/3 torque, but cancel 2/3 of the reverse emf
So you gain ~33% efficiency on a motor that runs at 85-93% already
mathematically, there is a quantity that "should not be there",
yet here there is a motor providing 66% of its max power
with 33% of its normal input.
it is the same process we consider "reactive power"
but the phase angle is different than what is considered
in power factor adjustments.
this is not just a metering issue.
Reactive power can be used outside of the normal increasing/collapsing field.
if we consider the times during the transition
which is what the 3-phase induction motor is designed to interact with
there are times during which both conduction and induction
occur simultaneously.
the 2-phase motor, or the 3-phase operating on only two coils,
have a direct relationship between conduction and induction.
But throw a 3-rd field into play, at anything other than the right time,
and both the forward and reverse relationship between the two change completely
sm0ky2
Quote from: evostars on January 14, 2018, 05:13:11 PM
I wouldn't go that far.
According to Maxwell, the magnetic field is always present,
when there is electric flux.
Though the magnitudes may seem small relative to ourselves
They most certainly still are there.
I'm pretty confident I could figure a way to prove this with nanoferrites
But it's probably a redundant waste of time like putting a c-speed particle clock
on a rapidly moving vessel.....
If we don't use it, we don't have to worry about it, until we do.
like an idea of this? Next time the power goes out, wait for your street side transformer
to kick back in, and throw a fork at it.
Or if you want to get fancy, set up a few hundred magnetized needles of strings around
your room when you charge a large sphere with static electricity and shock yourself.
(homework: why do dense steel needles react more violently than soft-iron paper clips?)
