V Gate experiment using a Ring Magnet
Started by vineet_kiran, January 30, 2018, 07:56:59 AM
vineet_kiran
Video :
https://youtu.be/RCjekus9zLM
When magnetic field on the surface of a ring magnet is compressed using a small disc magnet with repelling pole,  the steel plate fixed on the surface of ring magnet is attracted towards compressed magnetic field area.  If oscillations of compression by disc magnet is synchronized with ring magnet movement, then the magnet rotates continuously.
If you conduct the experiment,  you will see that,  at higher speeds, the force required to move the disc magnet becomes very less.  if this force is less than the force with which the steel plate is pulled towards compressed magnetic field area,  then it will lead to overunity.  It is very difficult to synchronize the movement of disc magnet with rotation of ring magnet by hand because it attains high speed if field is fully compressed.   If it is mechanized like a V Gate,  then the motion of ring magnet may become perpetual.
Belfior
Hmm what happens if there is a steel plate on top of the ring magnet? Does it still work?
sm0ky2
If it touches twice it makes 2 compressed field junctions
You can also use a 2nd smaller magnet instead of steel
Or just 2 magnets opposite the bearing instead of ring
Or 8 in a circle and a small lever w mag
Or.... any field topology other than horizontal
vineet_kiran
Quote from: Belfior on January 30, 2018, 06:01:13 PM
https://youtu.be/M6FyfU2C724
When a steel plate is placed on ring magnet,  it absorbs the flux of ring magnet hence we will not get strong compressed field and it will not work.
As smoky2 said if two small magnets are placed on either side of bearing,  it becomes a case of normal repulsion. Whatever force is supplied by hand is converted to rotation of the wheel.
The idea of using ring magnet is, both compressed field and steel plate remain on the wheel itself and steel plate is attracted towards compressed field caused by two magnets,  i.e,  the ring magnet and the magnet in hand whereas we have to move only the magnet in hand.  Hence there is a chance of steel plate being attracted to compressed field with twice the force required to move the magnet in hand for compression which will lead to overunity.
sm0ky2
If placed on a mechanical lever, two things happen
1) you remove the unknown variable of "hand"
And 2) the drive magnet becomes fixed along a set path.
          which eliminates circumferential oscillations of the drive magnet
          providing more rotational torque.
Overunity is not observed by hand, because you spend more energy trying
to hold the magnet still, than it takes to rotate the wheel.
You have to think in terms of Howard Johnson magnetics
As the magnet approaches the compression field it attracts
As it leaves it pushes the magnet back up
With the large piece of steel, the magnet can be attracted to the steel
which may cause problems, but placement and timing can dodge that situation
The function is in the field compression
Or change in flux over distance
If you think in terms of "field lines", there are more lines of flux in the compressed
part of the field, than there are in the relaxed (expanded) part of the field.
Magnets are always attracted to the point of lowest magnetic potential.
That is the most "lines of flux" per area, over the shortest distance.
They are repelled, to the point of greatest magnetic potential.
That is the least "lines of flux" per area, over the greatest (effective) distance.
Attract in, repel out.
Essential function of a magnetic gate.
The magnetic portion is not constrained by thermodynamics.
There is no time in the equation.
Energy includes time.
The mechanical portion is always entropic.
This is where people fail.
In a direct "OU" approach, the system should be designed such that
Entropy < Negentropy
Magnetic translational force over distance, must be greater than frictional losses
and other resistances in the system. (including undesirable magnetic effects)
