170 watts in - 1600 watts out - looped - Very impressive build and video
Started by e2matrix, February 17, 2018, 01:03:05 PM
ariovaldo
Quote from: Acca on February 21, 2018, 12:04:24 PM
Ari how are you going to eliminate the back EMF ?  This is where the relays switch to capture the downward collapse of the magnetic opposing the field .
Acca..
For now, I will test taking in consideration the BEMF. I will test the rotating magnetic field in the motor stator and it effects in a inner coil.
Lets to see.
Thaelin
Sadly I have to call foul here. I have the d/l mp4 and noticed at 7 minutes on there are two glitches. Watch the voltage on the super cap bank.  From 21.2 to 22 then to 24. So is not one continuous take but 3 pieces together. Not sure that means anything at all but in this game, well you all know.
The schematic shows 36 transformers and  two diodes to each. One is in shorting mode and so cannot recover any bemf at all. So what is he really sending back to the big hot resistor.  OH WELL
thay.
Jeg
Quote from: Thaelin on February 24, 2018, 10:56:48 PM
thay.
Hi Thaelin
If you are referring to the schematic on page 1, then this is just a speculation of the possible schematic by the member x_name41. Doesn't mean that it's the real one. ;)
smoky
#Orialdo
Start with a high frequency not a low frequency if you don't want to fry your stator coils!
Low freq= low reactance and with rotor removed even less inductance possible in stator coils.
Gerry
profitis
"About the Russian generator, any similarity is just
a coincidence"                                this with the russi device would be the bomb dude
