170 watts in - 1600 watts out - looped - Very impressive build and video
Started by e2matrix, February 17, 2018, 01:03:05 PM
konehead
Hi Erfinder
Pehaps you mean that H switching will not work right, since it breaks the fields when OFF...
.rather the fields should be all connected in series like one long string with end connected to beginning and the pulsing of power into this string enters at certain "points" within this string?
Perhaps the sections of this long string do not connect via wires, but the transformer effect of the shared-slots where ends of coils meet?  (long shot idea but could be at least I am thinking about it)
Sorry about the shorted coils thing, I thought there is some bit of evidence the shared slots create this situation and hyper-ringing effect to some degree, maybe insignifigant and just causes some interference seen on the scope.
konehead
Hi Erfinder
H re is that drawing again by Skipperbythesea (Gary Porter) you mentioned and pulsing-sequence...
Note the drawing does not have shared-slots, rather side by side arrangement.... also note the 6 pointed star in midde of it all too....
gotoluc
Message to group from Pierre
hello,
I have a question regarding a possible optimization of the dz generator.
I'm not a magnetic field specialist so I would like to know what would be a better design for the center fixed generator core. Should the center Iron core cover the whole field like the first picture or like second picture with the wire in the center of the I core like my first device?
I would like peoples opinions which I may consider using on my second prototype.
Thanks
Pierre
Text francais de Pierre
bonjour luc , j'aurait une question pour optimisé le dz générateur vu que je suis pas un spécialiste des champ magnétique j'aimerais savoir si le rotor qui génère la torsion du champ devrait-elle faire le champ au complet ou  concentrer le fil dans le centre mais sans couvrir le champ au complet. J'aimerais que quelqu'un me confirme ça pour aller chercher le maximum de puissance dans mon deuxième prototype.
merci
Pierre
pedro1
memoryman
Imho, Pierre should first establish that he did what no other person has done before (as far as we know): making a self looping OU device.
To be credible, the video should show that there is no possibility of an external energy source. Proper input and load measurements (with good calibrated equipment) would be very useful. Until it has been clearly independently verified, this is a wild goose chase. This site is rife with claims that are unverified.
