170 watts in - 1600 watts out - looped - Very impressive build and video
Started by e2matrix, February 17, 2018, 01:03:05 PM
pedro1
I'm sorry people like you who thinks I'm doing magic I thought I'd have a hand with you but I can see that you do not have any suspicion about me I just put the program on line arduino i hope you did it fast because i already took it off i did not want you to help but in the future it will make you get by without me seriously think i was working on it's concept of the generator dz for months to do more magic for those who think I wanted to make a money shot with youtube know that my account is not even paying I spent a lot of money and a lot of time in this project without expecting to have 1 cent in return I wanted to give a maximum of information for free for everyone I was offered money to continue my research but I refused too, so when you me said that nothing is proven in the free generator dz has you to believe me e or not but I know what I did and that no one else had yet to think to do and my video proves good luck to all for those who want to replicate the generator dz I will come back maybe one day with a functional prototype anyway I used to work alone to read comments like that I wonder why and thank you to the other who believes in the generator dz I think it's the future.
        pierre cotnoir
bon j'en ai mare des gens comme vous qui pense que je fait de la magie je pensait avoir un coup de main de votre par mais je voie que vous n'avez de la suspicion envers moi  je venais de mettre en ligne le program de l'arduino j'espère que vous avez fait vite parceque je l'ai déja enlever  je ne voulait que vous aidez mais a l'avenir il vous feras vous débrouiller sans moi pensez vous sérieusement que j'ai travailler sur se concept du dz générateur pendant des mois pour faire de la magie ,de plus pour ceux qui pense que je voulait faire un coup d'argent avec youtube sachez que mon compte n'est même pas payant j'ai dépensé beaucoup d'argent et énormément de temps dans ce projet sans m'attendre d'avoir 1 cent en retour j'ai voulue donner une maximum d'information gratuitement pour tout le monde je me suis fait offrir de l'argent pour pousuivre mes recherche mais j'ai refuser aussi, alors quand vous me dite que rien n'est prouvez dans le dz générateur libre a vous  de me croire ou pas mais moi je sait ce que j'ai fait et que personne d'autre n'avait encore penser a faire et ma vidéo la prouve, bonne chance a tous pour ceux qui veulent répliquer le dz générateur je reviendrai peut être un jour avec un prototype fonctionel de toute façon j'ai l'habitude de travailler seul a lire des commentaire comme ca je me demande bien pourquoi et merci au autre qui croit au dz générateur je pense que c'est   l'avenir.
        pierre cotnoir
pmgr
What I suggest is that Pierre makes a second prototype exactly the same and confirms that it works overunity, then after that he can start changing things, but only one by one, e.g. replace relays by transistors, check if it still works, change the shape of the center coil, check if it still works, etc.
In that way we will find out step by step what is important for the operation of this device.
With his help we have currently figured out how the coils in the stator should be winded and positioned.
What we need next is a full schematic of his setup (including the coils, relays, transistors, etc) and the Arduino sequence and timings for switching the 36 coils.
With respect to his device, most of us take him as an honest man who speaks the truth. I personally assume he is not making false claims. If he is, he should think about all the time and money people are spending here on trying to replicate his device and make suggestions to improve it.
One simple test Pierre can do is to plug in an old fashioned 100W light bulb and let it run for 5-10mins self-looped to show that the device is really self-sustainable and not running form the caps.
With respect to his question about making a different rotor:
1. A full sized round rotor would break the 3:2 asymmetry of the current device (but since we don't know it's operating principle, it's not clear if it is important to retain it).
2. A narrower center coil might be better to avoid pole fold back through the edges of center coil, but making it too narrow would increase the magnetic resistance of the center coil and allow for less flux through that coil, thus lower output.
PmgR
* Truthfulness * Compassion * Forbearance * www.falundafa.org
French translation of PmgR post
Ce que je suggère, c'est que Pierre fasse un deuxième prototype exactement le même et confirme que cela donne de la surunité, après, il peut commencer à faire des changements une chose à la fois, par ex. remplacer les relais par des transistors, vérifier si cela fonctionne encore, changer la forme de la bobine centrale, vérifier si elle fonctionne toujours, etc.
De cette façon, nous allons découvrir étape par étape ce qui est important pour le fonctionnement de cet appareil.Avec son aide, nous avons actuellement compris comment les bobines du stator doivent être enroulées et positionnées.
Ce dont nous avons besoin ensuite est un schéma complet de son installation (y compris les bobines, les relais, les transistors, etc) et la séquence Arduino et les horaires de commutation des 36 bobines.
En ce qui concerne son appareil, la plupart d'entre nous le prennent comme un homme honnête qui dit la vérité. Personnellement, je suppose qu'il ne fait pas de fausses déclarations. S'il l'est, il devrait penser à tout le temps et l'argent que les gens dépensent ici pour essayer de reproduire son appareil et faire des suggestions pour l'améliorer.
Un test simple que Pierre peut faire est de brancher une ampoule à l'ancienne de 100W et de la laisser fonctionner pendant 5 à 10 minutes en auto-boucle pour montrer que l'appareil est vraiment autosuffisant et ne fonctionne pas juste des super cap.
En ce qui concerne sa question sur la fabrication d'un rotor différent:
1. Un rotor rond de taille normale casserait l'asymétrie 3: 2 du dispositif actuel (mais puisque nous ne savons pas son principe de fonctionnement, il n'est pas clair s'il est important de le conserver).
2. Une bobine centrale plus étroite pourrait être préférable d'éviter le repliement du pôle à travers les bords de la bobine centrale, mais en la rendant trop étroite augmenterait la résistance magnétique de la bobine centrale et réduirait le flux à travers cette bobine.
PmgR
seaad
This is an Achilles heel:
SONGLE RELAY
http://www.circuitbasics.com/wp-content/uploads/2015/11/SRD-05VDC-SL-C-Datasheet.pdf
Max. ON/OFF Switching
Mechanically   300 operation/min
Electrically        30 operation/min
Life Expectancy
Mechanically   10^7    Min. (no load)
Electrically     10^5  operations. Min. (at rated coil voltage)
So I hope the finding of real OU Can be noted fast before the relays crashes
iflewmyown
Very nice job, thank you for taking the time to video the process.
Garry
