170 watts in - 1600 watts out - looped - Very impressive build and video
Started by e2matrix, February 17, 2018, 01:03:05 PM
seaad
My view is that the fifth video is misleading.   https://www.youtube.com/watch?v=Nh4cC9hIXbg
Here Pierre shows (ONE) current path through six coils times 6=36, with 6 active switches.
My opinion is that there are fewer coils used (ON) when running.  Each pole 1+1 coils, Or multi coils overlap.
Looking at the blue LEDs when ONLY SIX of them steadily lights in a film frame. A situation between switch events.  Not at a frame with  2 + 3 + 3 blue LEDs, for example!
Now you can count that MORE THAN SIX (6 ---> 12) RED LEDs on the Relay boards ALWAYS are lit?
Some shining LEDs are hidden behind the cabling in some frames and can't be seen!
Regards / Arne
Ps: You can see that it seems to be one RED LED emty relay RED LED   at 1, 2 -- 4, 5 --7, 8 -- 9,10
MichelM
Selon Pierre (réponse à ma question dans les commentaires de sa dernière vidéo, sur Youtube),
il y a 6 X 6 bobines sous tension.
Je vous propose de regarder cette animation que j'ai faite, selon ces indications : https://youtu.be/8moN-nDHvzU
Il faudrait que Pierre regarde cette vidéo et nous dise si cela se passe ainsi.
English
According to Pierre (answer to my question in the comments of his last video, on Youtube),
there are 6 X 6 coils energized.
I suggest you watch this animation that I made, according to these indications: https://youtu.be/8moN-nDHvzU
Pierre should watch this video and tell us if that's the way it is.
gotoluc
Quote from: Floor on March 21, 2018, 10:55:39 PM
@Gotoluc
QUOTE
"I agree, 30 is not 36 but it's what I had available and better than nothing as a starting point.
If anyone wants to send me a 36 I would be glad to test it as well. Just send me a PM"
END QUOTE
QUOTE
"Okay, we set it aside and do what exactly?"
END QUOTE
Don't finish the build untill you have the other.....
If some one wants to see a replication strongly enough they will send you what you need.
Or, maybe don't set it aside, and we see what we see.
Then lets not consider your present build as a replication either, but rather as a related
experiment.
                      best wishes
                               floor
français
Ne terminez pas la construction jusqu'à ce que vous ayez une 36 fente .....
Si quelqu'un veut voir une réplication, il vous enverra ce dont vous avez besoin.
Ou, peut-être ne pas le mettre de côté, et nous voyons ce qui se passera
Ensuite, ne considérons pas votre construction actuelle comme une réplication non plus, mais plutôt comme une expérience.
I see, I thought it was clear right from the beginning of my participation that my build cannot be considered as a replication?
So just in case anyone else thinks it's a replication let me make it clear, it's not a replication and never can be considered as a replication.
I'm building with what I have on hand and what partzman has shipped me.
This build will only be to observe the effects of coil on time overlap and a rotating magnetic field. Like I already wrote, if it does more then that's a bonus!
Can all those who do have a 36 slot stator and are building a replication, please come forward (post) or pm me to let us know someone will be building and testing a 36 slot.
Luc
français
Je vois, je pensais qu'il était clair dès le début de ma participation que ma construction ne peut pas être considérée comme une réplique?
Donc, an cas où quelqu'un d'autre pense qu'il s'agit d'une réplique, permettez-moi de le préciser, ce n'est pas une réplique et ne peut jamais être considérée comme une réplique.
Je construis avec ce que j'ai en main et ce que Partzman m'a envoyé.
Cette construction sera seulement pour observer les effets de bobine en chevauchement (overlap) et un champ magnétique tournant. Comme je l'ai déjà écrit, s'il en fait plus alors c'est un bonus!
Est-ce que tous ceux qui ont un stator 36 fente qui sont en train de construire une réplique, s'il vous plaît, venez nous faire savoir que vous tester un 36 fente.
Cordialement
ariovaldo
Quote from: gotoluc on March 22, 2018, 08:58:50 AM
Luc
français
Est-ce que tous ceux qui ont un stator 36 slot qui sont en train de construire une réplique, s'il vous plaît, venez nous faire savoir que vous tester un 36 slots.
Cordialement
Good morning Luc. Your windings looks like a professional grade. Good job.
Ariovaldo
