user TURBO?s replication of Steven Mark?s TPU ?
Started by turbo, November 29, 2006, 04:13:49 PM
0 Members and 50 Guests are viewing this topic.
Moab
On the microwaves
I do not think it is radiation of this kind, None the less, I will bring home a leakage detector tomarrow and shoot it. I think this prudent at least to check it out. Tesla lived well into his 90's and if there has ever been anyone in history that has been in close contact with and prolonged exposure to this kind of thing, surely he was. No i do not think my devise is imetting microwaves. Scalar? Probably. Aether? maybe. Magnettic? Deffinately.  what gentelmen say you on this?
Moab.
MrMag
HELP!!!
I need a little help over here. I've wound and connected as per Otto's diagram and all I get out is what I put in. I have a feeling it may be due to the fact that I am using 3 different signal generators. 3 different power supplies feeding the coils probably doesn't help much. Anyone have any ideas. Should I dig out my MOSFET's and have the generators fire them?
And also a question for Otto. You mention back a ways that you take the power off of the point where the collectors meet with the feedback. According to your drawing, the collectors do not connect to the feedback. Did I misunderstand? Maybe it's just not shown in the drawing?
Giantkiller,
How did you make out with that light bulb? I see that they are already starting to put up billboards with you on them. Something about the second coming. You aren't paying them to do that, are you? ;D
Hello guys,
I told about this east-german inventor,
Name: Siegfried Stargard("nomen et omen"),
one of his other inventions:
cryo-cooling,based by transformer ,DE4035445 !!!
Good luck
             dL
p.s.: he delivered really fine stuff,read all his different invention,
gravity-/voltage-/cryo-/vaccum- related,
the only handicap: in german language !
Yamanashi Jr
X, congratulations.
(Ps: SM, Mannix, TURBO; Stefan et all tanks)
Your work is divine. Work-of-Art as I use to say.
...Hello mother!
When the party is over
... I just keep dancing to the rhythm
giantkiller
Quote from: aether22 on January 05, 2007, 09:02:16 PM
GiantKiller, I have all the coils now wound in the same direction (which due to the connection system makes the fields opposing) in what is seen from above in a clockwise progression around the torus starting from the negative terminal. (though it strikes me that the only difference between a cw progression vs a counter clockwise progression is which way is up, turn it upside down and it's a ccw progession)
As per your instructions over the top, through the hole and around the back, this breathes a bucking B-field.
So this diagram is correct right? (it must be)
BTW is you have an iron ring collector insulated from the rest, and charge it positivly there is a chance of lift-off (though you may need more tpu's with opposite aether flows), or if you get a few and interlock them or otherwise have several focusing on a point you will also get levitation.
Finally if you manage to overload steel wire (and maybe iron wire) in the right way it will turn transparent then invisible. (got lots and lots of stories I have correlated about that)
It seems steel just isn't able to take too much excitement, it stops responding to light in any way.
The bucking field coil is the transformer off the 390721 patent. I stared at that for days. I stared at his other diagrams. He was able to put things in the diagrams and not account for them. That is what struck me to one of my tests on TPU#3. Big copper but I was able to get harmonics. Not kicks though because the cu gauge / input voltage ratio was wrong. The controller needs to alot of small fields not a few big fields. That was the build it and toss it philosophy. We were all there at the same time just a' winding away.
Yes, your diagram is correct. Now forget the science and wind. The explainations come later when everybody can run TPUs instead of pondering TPUs. Been there done that as alot us have lost alot of sleep over this.
You must be new here...
I want a 4x4 array of SM17s on computer controlled gimbles on a platform in a shell. This will get me the propulsion I need to get home.
Can you feel the power?
When it comes to changing or harming steel? You only need to speak the masters name, Hutchison.
--giantkiller. A picture is worth a thousand words. How much is this technology worth?
Think of the change you have to perform now. And no, I am not this for the money. Its only points. Remember 10k children die of starvation every day, 2 million abortions a year, average 2 million die a year of aids. Homeless people, orphans, unemployed. I wasn't going forget the reason? It takes dollars to fix a problem of this scale. This is my next project.
I was given a book by a close associate. It is called 'Streams in the desert' by Zondervan press. It has a passage to read for every day of the year. I haven't kept up. So I though today would be a good day to do just that. So I go to Today's date and lo and behold I get snapped. It reads Then Asa... said "Lord, there is no one like you to help the powerless against the mighty." (2 Chronicles 14:11). These days of mine are filled with wonderment! I am glad you are all here to witness the great things.
