Back-EMF Manifesto - A Key, hidden in plain Sight.
Started by dieter, February 18, 2018, 08:06:28 PM
sm0ky2
Quote from: Erfinder on February 19, 2018, 11:38:16 AM
the time constant is an issue....how will you circumvent it?
3Mv electric-field, pulsed at 925Hz
phaseshifted by variable inductance
to dialate local time-space around the machine.
tomd
Quote from: forest on February 19, 2018, 04:06:39 AM
Please draw schematic, because if you place load along the coil in series connection then it is the same as ordinary one, I think you mean : place load at the back-emf spike path ?
Where is the "back-emf spike path"? Do you mean parallel to the coil?
Didn't anyone notice this howler?
QuoteSo, theoreticly, two heaters in parallel will consume less energy than only one.
But of course we know that this isn't true at all, and conventional electrical theory conforms with the results of experiments in this matter (agrees with past and correctly predicts future experimental results).
So there is something terribly wrong with your "theory".
dieter
Quote from: TinselKoala on February 19, 2018, 08:17:51 PMDidn't anyone notice this howler?But of course we know that this isn't true at all, and conventional electrical theory conforms with the results of experiments in this matter (agrees with past and correctly predicts future experimental results). So there is something terribly wrong with your "theory".
[/font]Something? Something. Funny.But I am not here to talk to little minds nor to play with puppies..Great minds may read my words and understand, silently.
dieter
Quote from: tomd on February 19, 2018, 04:23:16 PM
When the Pulse ends, the current reverses direction. The Voltage is higher in the coil than in the power supply, therefor that is a potential diffrence, the coil charges the supply for a brief moment.
You can use Diodes to make this reverse current flow over a diffrent path. Sometimes called Flyback Diode.
