ltseung888
Email to
public-affairs@international-space-agency.us
rick.dobson@international-space-agency.us
Dear Sir,
I am interested in the Centrifugal Propulsion System "Closed Loop Propulsion" Program Office (CPS-PO) under development in secret for 27 years, and went public January, 2013.
I approached the problem from a different angle.  Some Christian friends named the approach as the King David Sling technology.  The Sling can have increased circular velocity and let go in any direction - up, down, left and right.  If the string of the sling were replaced by a magnetic attraction force, the stone or magnetic weight can move in a circular path without touching the circumference of the vessel.
If that attractive magnetic force were broken, the magnetic weight would strike the circumference and tend to fly away in a tangential direction.  If a proper impact or collision mechanism is set up, that flying away force will provide the linear thrust.  That linear thrust may have a vertical component and drive the vessel up in a spiral path similar to a Flying Saucer.
Details can be found in
http://overunity.com/1763/12-times-more-output-than-input-dual-mechanical-oscillation-system/msg445805/#msg445805
I would appreciate if your experts can comment on this King David Sling mechanism.  Please post in Overunity.com so that all can benefit from the knowledge.
Lawrence Tseung
Retired Physicist from Hong Kong
ltseung888
https://www.youtube.com/watch?v=IbmBhuKBH-k
Spinning top.
If the top were unbalanced...
Would the weight fluctuate?  Would gravitational energy be lead-out?  The William Skinner device has such elements?
ltseung888
I still have not understood the solid mass centrifugal propulsion system yet.
Can someone help?
From my limited understanding, the device uses centrifugal force from 40 wheels.  Each wheel will have the unbalanced mass at the top in the rotation.  The Centrifugal force from all the 40 wheels are upwards.  One wheel may not provide enough centrifugal force to lift the vessel but 40...
This is not as powerful as the electromagnetic King David Sling mechanism...  But it clearly illustrates the power of the unbalanced wheel.  ISA already has an operational prototype from their description.
Lawrence
reply 3156
Mr XYZ
Lawrence, you won't get an answer from this person (Rick) as he has 'disappeared' !
Here's what I posted earlier: "- Here is a quote from a guy who was associated with Mr. Rick R. Dobson - "I personally know Rick and he has disappeared.  His house was firebombed because of vids like this and he went to the wilderness" ! - Hmm, so if it was without foundation and unworthy of serious attention, then why such heavy opposition from the power-brokers? ...
Email to
Dear Sir,
Lawrence Tseung
[/quote]
ltseung888
Quote from: Mr XYZ on May 14, 2015, 02:50:40 AM
Email to
Thank you, Mr. XYZ,
I think that the International Space Agency initially does not appreciate the significance of such work.  Some of their scientist might have dismissed the work as worthless.
That happened in China also.  But as soon as the information is declassified, some bright souls ...
The fact is clear now - both China and USA has some form of lead-out energy flying saucer in development.  When will they disclose such paradigm change technology to benefit the World?
Lawrence
reply 3156
