0 Members and 27 Guests are viewing this topic.
supersam
at all:
i just do not get it!  you go from zero gravitational force to three times the force,  ( in a matter of seconds), and you can't understand that this could be used for mechanical leverage, and harvested at the fulcrum of the lever, and still bounce back to, at the least reset the pendulum!
take for instance if you set the lever up at a four to one ratio, will you not have twelve to one output at that point? can you reset the pendulum with that power output and still produce excess energy?  it, just seems possible to me.  even knowing that it can't be done.
lol
sam
supersam
hi all:
i guess what i am trying to say is that since my windmill doesn't have to pump water from two hundred feet anymore, by it's self, my cows now have alot more water available.
just think of the wind power alone!  trust me it doesn't take near the power for my windmilll to slap a pendulum, as it does for it to pump water four feet, let alone two hundred.  i think this should speak for it's self.  once you move one gallon of water up one foot then with the same force you can move it however far you need it.
the thing i am thinking about now is how to make this overunity.  the rest has already been shown.  but how do we close the loop?
lol
sam
FreeEnergy
Quote from: supersam on August 10, 2007, 08:47:38 PM
hi all:
just think of the wind power alone!  trust me it doesn't take near the power for my windmilll to slap a pendulum, as does for it to pump water four feet, let alone two hundred.  i think this should speak for it's self.
lol
sam
i can't wait! sooner or later we will crack the code for self powered machines based on gravity.
supersam
FE:
have you been hiding under a rock? i just said if you can slap a pendulum with a windmill every few seconds you can pump a one inch column of water over two hundred feet. yes it takes a few more foot valves, but so what in the long run.
no i don't have an eternal supply of wind either. however, most of the time i have enough to slap the pendulum!
lol
sam
ps: maybe i should consider batteries!  hummm!
FreeEnergy
Quote from: supersam on August 10, 2007, 09:33:00 PM
FE:
lol
sam
how are you "slapping" a pendulum with a windmill. got a picture?
p.s. ever though of using the drinking bird? http://www.overunity.com/index.php/topic,2421.0.html
