Experiments On The Bifilar Coils Ability To Take In Electrical Impulses
Started by Magluvin, March 05, 2018, 05:28:05 PM
Magluvin
Quote from: AlienGrey on March 05, 2018, 07:00:21 PM
Any chance you can define BIFILAR' before you start ?
Only i have seen Caduceus coils, bucking coils, and above all a GRENADE coil referred to as bifilar on these treads which it has none as such.
AG
http://www.tfcbooks.com/patents/0512340.htm
Mags
Magluvin
I was ready to go home and found I forgot to charge my bike.  So I went back to the bench an fiddled.  I made some changes that solved an issue or 2.
I changed the pickup coil to the coil I was using as the kicker. The other coil was the reason for the blobbing and the lower chop in the bifi and the crap really screwing with the single coil with the cap. So that is solved. And using the large inductor for the kicker got rid of the interaction of the kicker coil and the test coils., at least as far as I can see.  It all came together in a short period of time. Speaking of time, Im not going nowhere for a bit so I did a vid of what I found that shows some significant differences between the bifi coil and the normal coil with a capacitor, tuned as close as possible to the bifi resonant freq.
I cover the push button switch also.
https://youtu.be/bu6aNl6AL5I
Mags
Magluvin
These are shots showing the issues I had before fixing them as said in my last post
Mags
hoptoad
Quote from: Magluvin on March 07, 2018, 03:16:58 AM
snip....
Mags
Glad you forgot to charge your bike.  :P
Nice straight forward presentation. Interesting results. Thanks for sharing. ;)
Cheers
Magluvin
Just for giggles, I tried each coil with the pickup coil to the face of the coil being tested. The voltage difference is substantial. Shots below.
Ya know, back some years, Luc was testing some bifilar coils and I had suggested the possibility of the bifi coil might perform better with higher voltages. i have to remember what led me to that. But he said it didnt help.  I dont remember if he was comparing a regular coil like I am here.  But it sure does look like things are going that way.
Mags
