Pierre's 170W in 1600W out Looped Very impressive Build continued & moderated
Started by gotoluc, March 23, 2018, 10:12:45 AM
listener192
Quote from: jerdee on June 04, 2018, 09:42:10 AM
AMEN!!!! 110% agree!!!
I thought we previously agreed that what we see with the moving stepped waveform is flux linkage as in a transformer. Obviously not the same as flux cutting with a flux moving in space. So this has always been the question how do you simulate the quantum effect of a flux moving in space?
L192
T-1000
Quote from: listener192 on June 04, 2018, 10:29:34 AM
The answer is in moving magnet case. The 3D position of N/S polarities are changing while the constant strength of magnetic field is maintained inside of the magnet.
In transformer we alter magnetic field strength inside of the magnet and the 3D position of N/S poles are not changing.
By making overlapping windings and overlapping switch-on/switch-off delays in those coils we are making N/S poles 3D position change while magnetic field strength of mutual virtual magnet is not changing. The rest is same as with moving magnet case.
P.S> If you have offline copy of first Pierre's video please see how magnet moves inside his alternator with frame-by-frame sequence.
listener192
Quote from: T-1000 on June 04, 2018, 10:35:59 AM
The field is a series discrete fields arriving at slightly different angles to the rotor however, this is not a contiguous flux moving in 3D space. Physically it will drag a magnet around by virtue of the change in the flux level i.e. the stepped waveform. The rotor sees a change in polarity and also flux strength changes. For the short run I had with the bridge boards I had substantial rotor output current that was lighting a 60 W bulb so there was flux change however, the device performed like loose coupled transformer.
Referring back to a previous post...
There is nothing special about the overlapping windings they just produce a stepped flux increasing and decreasing in amplitude and alternately changing polarity. The six coils examined as one set of coils on the stator just add their fields where they physically overlap. You can verify this with a flux probe which I have done.
L192
onielsen
Quote from: listener192 on June 04, 2018, 11:17:54 AM
L192
Hi L192,
If there's nothing special about the way the fields are generated then do you think that a standard 3-phased stator with suitable 3 phased current will give overunity too as claimed in the Molina-Martinez and Hyun Chung patent applications? This would make it possible to make a self-runner by using a three phased frequency converter which are off shelve devices.
QuoteThe six coils examined as one set of coils on the stator just add their fields where they physically overlap. You can verify this with a flux probe which I have done.
Are you sure the fields are just added and not actually becoming coherent. If coherent the field strength is more than added. Then the currents are squared after the addition while as single fields they are squared before the addition. This gives big difference in field strength and is the key to extracting energy form the cosmic background according to W.B. Smith.
Ole
