Sergh
We all want to get results quickly with simple methods.
But that doesn't work. We must try to go the same way that Kapanadze went in order to understand.
We summarize the available information about the way:
1. Earlier than 2000, Kapanadze, on the basis of some information obtained as a result of some research by a team of some organization, invented a "car on the water".
2. According to some facts, it can be assumed that during the Soviet era, Tariel could work as an architect in the organization "Gruzgiprovodhoz", which specialized in research and development on water management, melioration, etc.
3. Tariel claimed that the initial principle of operation of all his devices was obtained in the study of the forces of gravity and antigravity, which was carried out by a group of researchers long time ago.
Summarizing these 3 points, it can be assumed that the topic of research at "Gruzgiprovodkhoz" could be the topic "Groundwater rise in various types of soils". As a result of these studies, a low-cost process for producing hydrogen was somehow found. No military secrets, flying saucers and other mysticism.
What would be the name of the unexpected effect found by this group of researchers, which would correspond to line number 1?
Something like this:
"Anomalous release of a large concentration of hydrogen from some types of soil" or something similar, for example:
Quote"Hydrogen Emanations in Intracratonic Areas: New Guide Lines for Early Exploration Basin Screening"
Offshore the emissions of dihydrogen are highlighted by the smokers along the oceanic ridges. Onshore in situ measurements in ophiolitic contexts and in old cratons have also proven the existence of numerous H2 emissive areas. When H2 emanations affect the soils, small depressions and vegetation gaps are observed. These depressions, called fairy circles, have similarities with the pockmark and vent structures recognized for long time in the sea floor when natural gas escapes but also differences. In this paper we present a statistic approach of the density, size, and shape of the fairy circles in various basins.
https://www.mdpi.com/2076-3263/11/3/145
This scientific article confirms the presence of the desired effect, but does not provide information about the specific process that leads to the release of hydrogen. The strange small limited shape of these areas of hydrogen emission in random places leads to the idea that these may be traces of some ancient meteorites, etc. Maybe these circles contain some special mineral that spontaneously  dissociates water.
A deep analysis of information about this or similar effects is needed.
forest
Operational theory (another one... yeah): cosmic particles are coming to Earth and are stopped by magnetosphere while creating ions and something else which I think may be called soft
Bremsstrahlung ,
which is simply high frequency oscillating energy. It is dispersed in Earth magnetosphere so the method to tap it must be clever and similar to heat pump. Basically it is done by magnetic reconnection (creating a sink in magnetosphere) then use energy to ionize air around the circuit and then by some process move that ionized air around the circuit generating strong magnetic pulses which is then collected around by some kind of positive feedback.
That theory explains the energy source and while has a lot of holes may be the most simple explanation. That's why energy so collected was often calle datmospheric electricity.
ramset
Sergh
This https://www.mdpi.com/2076-3263/11/3/145
Must not get buried in the mix
Since your other "low temperature thermolysis" work hints at
Plausibility...
This needs a group .....thoroughly investigated..towards experimental suggestions ( example Zeolite etc etc )
Respectfully
Chet
Quote from: Sergh on April 21, 2023, 06:55:27 AM
Thanks Grandma
r2fpl
Some time ago I wondered if it was just electrolysis with an iron rod in the ground. It should be noted that Kapanadze dug a hole in the garden and placed the radiator from the car there. Then he flooded the entire area with water. In another video, we see him using the ground to a water pipe. Other locations are not shown except for one when the grounding is a building structure.
We must pay attention to one more very important detail: this is the current measured with a 24A clamp meter on the ground wire!!! How is this possible ? We know what the possibilities are and when you analyze all of them you will understand that the current is coming either from earth DC/DC pulse or AC.
If what Sergh says about hydrogen could be true, how to explain such a process? What does an iron pipe in the ground do that breaks down water into hydrogen when there's electricity on it. And how does this current flow back to us!?!?!
kolbacict
And when I look at these pictures, I remember another.
p.s. I'm sorry the joke didn't work.
Failed to insert GIF file-picture.
The second picture says:
Stop looking like a donkey and get back to work.
