Sergh
I found two old videos of Kapanadze with high-quality translation into Russian with captions. In YouTube settings, you can turn on the translation of subtitles into English. You must click the gear and select the option to translate subtitles.
Tariel Kapanadze - Disk Generator (with Russian subtitles) 2001
https://www.youtube.com/watch?v=ycrmPwny6bQ
In the video, the logo of the first television channel of Georgia, the journalist Merab, did not recognize his last name. TV channel website:  https://1tv.ge/
Quick summary of important information:
1. Kapanadze's engine is not a perpetuum mobile.
2. Kapanadze's engine is a gravitational engine.
3. The engine needs an electric generator to power itself. The engine needs electricity from a built-in 10 watt generator for continuous operation.
4. The development of the generator took 20 -25 years. From the date of the video, the beginning of work on the generator is 1976 - 1980. Soviet times.
5. Generator efficiency at least 1 in 1000.
6. The engine uses gravitational energy to run. With the help of gravitational energy, electrical energy is obtained.
7. Tariel does not know engines close in principle. This video shows the 3rd copy of the engine. The first, very small version, gave 1 kilowatt.
The second option was loaded with 40 incandescent lamps of 100 watts each. The output was an alternator.
This displayed 3rd option was created to demonstrate the principle. The axle rotates at 1800 rpm, you can add an overdrive to it and it will be able to turn an ordinary generator at 3000 rpm.
8. There was a hydrogen system, a system for separating water into hydrogen and oxygen, for use in a car. In April of this year, in the Russian magazine "Behind the Rulem" page 174, there was an article that a Filipino made the same system as Tariel's. The Filipino has a contract for 3 million a month that he will build a plant for the production of such devices.
(Tariel found the info about this Filipino from the ordinary magazine "Behind the Wheel" in 2001.
  So the invention of the "car on the water" must be dated earlier than 2001.
https://www.zr.ru/archive/zr/2001/04/avtoprobieg-na-lunu)
9. Kapanadze tried to produce the device at the Tbilisi Aviation Plant "Tbilaviamsheni".
The device was shown to the general director of the Tbilaviamsheni plant Pantiko Tordia:
https://www-nplg-gov-ge.translate.goog/bios/ka/00009998/?_x_tr_sch=http&_x_tr_sl=ka&_x_tr_tl=en
Kapa Banka - 28th April 2004 (with Russian subtitles)
https://www.youtube.com/watch?v=5s2t_puDDhI
1. From a 12 volt to 220 volt converter, 0.4 amperes are consumed at the output, about 100 watts. The light bulbs receive about 5 kilowatts, 50 times more. The generator receives 220 Volts 0.4 amperes, the output is 24 amperes.
2. The device initially worked in a vacuum, it was inconvenient to assemble it into a complete structure. Collected at the factory ("Tbilaviamsheni"?).
There must be a generator and the whole mechanism in a vacuum. The generator was taken out of the vacuum chamber to the outside to make it easier to maintain.
Between the mechanism, which should be in a vacuum, and the generator, an oil seal was installed, which did not let outside air into the vacuum chamber. But the generator got hot. (it is not clear what kind of generator we are talking about, probably transistors on radiators)
Then .. it is not clear .. offended and Tariel left the factory, where was the vacuum chamber? The video is probably shortened here. Tariel took the device with him and was able to make it work without a vacuum. But in a vacuum, the device could generate 2 to 3 times more power.
3. The first generator was for a power of 1 kilowatt.
4. Mamuka Khazaradze invited a scientist - physicist to demonstrate the device.
5. The device does not violate the law of conservation of energy, because it works in a system that has more than 3 dimensions.
6. Ether fills space. All space is filled with energy. "Theory of curved fields"
7. The generator can work without self powering at all, disconnected from the 220 V converter, "by inertia" for a couple of seconds. Strange sound after turning off 220 V. Tariel suggests that this can be used to completely eliminate self powering.
Source:
https://mazeto.net/index.php/topic,11560.0.html
dsquared18
Hi Sergh,
I'm confused. Why would you want to eliminate self running?
Cheers,
D2
ramset
Toronto is not far from here ( day trip 10 hrs? Long day)
Perhaps Mr.bunk will allow an onsite demonstration?
Quite certain Stefan could support live stream here ?
We desperately need this technology out to the world
Also there is a lab in Toronto area which might assist?
Perhaps a separate thread for this ?
( sorry for spaces in post ,please fix if ? ( hard to plunk on phone)
Note to Sergh
Thanks for videos ( hopefully discussion
EDIT for comment below about language barrier (also proper use of meters actually requires pantomime ( no words)
Even sealed box demonstration is doable with proper measurement equipment at site .
Ultimately
Language Not an issue , will just have to arrange proper venue..this is land of immigrants
Also translation technology is certainly available at lab or for live streaming (?)
If bunk is interested he should contact forum owner Hartiberlin to get ball rolling?
As mentioned
World desperately needs this asap ...
Thanks Grandma
pix
Stivep.
I am not surprised the outcome of your interaction with Mr, Bunk.Do you really think he has something of value? ::)
If he do have alleged US patent, why didn't he show it?
Anyway, if you know his name just check patent database.
Cheers,
Pix
_________________________________
My personal view at Bunk is  absolutely very much like yours.
Wesley
