0 Members and 45 Guests are viewing this topic.
Sergh
Quote from: r2fpl on July 20, 2023, 09:10:50 AM
This is the same setting  ;D
The image is blurry and the winding of the bobbin seems to be different in diameter.  In the middle is white electrical tape.It looks like the coil has been modified.
Quote from: rakarskiy on July 20, 2023, 09:28:23 AM
Budyonny first used high voltage to ignite the arc,
Uh, first. But the first  was only in Russia. Read  about the "Welding Oscillator" and think about what Budyonny has to do with it.
Low-power welding transformer. According to reviews of the "Rusich" apparatus, welding was poor because there was not enough power and the device overheated until the plastic case melted.Let's not involve Budyonny in this topic.
r2fpl
Sergh: It's just that the elements are in the same places.
r2fpl
Quote from: Sergh on July 20, 2023, 09:32:40 AM
The welder diagram may be relevant for some solutions, but it is not the same as a diagram with ferrites inside.
rakarskiy
Can Hedgehog and Viper be crossed?
https://www.youtube.com/watch?v=D43bipwBVgs
At one time I used this principle to make a reactor for oxygen-free "kreging" of gasoline vapors on board a car. The spark was good, but I had to say goodbye to a part of my teeth and periosteum, so now I bypass arresters by the tenth way.
The capa has a small spark for the pulse. You can pump a magnetic field, but you can also pump an electric field, probably the mouthpiece did it. At least that's my theory.
rakarskiy
Quote from: r2fpl on July 20, 2023, 09:47:03 AM
It is undeniable (not equal), but the principle is identical in my opinion. I have described it all in my work.
What if!? Devils sometimes make jokes!   ;)
___________________________________
https://rakatskiy.blogspot.com/2023/07/the-mystery-of-kapanadze-generator.html
