stivep
https://patents.google.com/patent/US4127804A/en?oq=us20150102676
this  is yet  another way to vary capacitance  .
If it is used  in conjunction with ..........https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg525072/#msg525072
than it will  replace capacitor 11.
However this patent is independent energy conversion unit :
QuoteTwo inversely ganged variable capacitors having a common movable element varying the capacities such that when one capacitor is at maximum capacitance, the other is at minimum capacitance, have, after initially charging, a substantially constant contained or trapped charge distributed between the two capacitors. As the capacities of the capacitors are varied, a potential difference is developed between the fixed plate of one capacitor and the fixed plate of the other. When these two potential points are connected to a load, charge is transferred from one capacitor to the other as a current flow through the load. The total charge is not diminished, the energy supplied the load being the energy expanded on moving the movable charged plates. As the movable plates are moved in a cyclic manner an alternating current is provided to the load.
Wesley
stivep
us20150102676A1
https://patents.google.com/patent/US20150102676A1/en?oq=us20150102676A1
the patent listed by me in https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg524989/#msg524989
contains scrambled pictures difficult to read.
I was encouraging you to study that patent
All of them can be employed in two ground system utilizing Telluric current as interacting  Factor.
relation of ionosphere/  earth  wave-guide/ telluric current
Wesley
magpwr
Quote from: Void on August 20, 2018, 12:28:59 PM
Hi magpwr. I don't know, but this company might be able to help you:
https://www.awcwire.com/part.aspx?partname=rg56
hi void and stivep,
I am not sure what kind of coax cable Akula used for Antenna.But it would be nice to know.But i do notice there is a pattern related to coax cable with low Impedance say 48 or 50 Ohms does come with a thicker center copper core.This copper core looks like the only thing would allow the Antenna to stay in place.
I will try awcwire but the only thing i am not comfortable with is the RFQ part instead of the online Cart.
This circuit i attached may be considered old news but new in many ways only after i explain.
Thaelin
  Not sure this will be of any help or even on topic. Delete if desired.  In my early 20's, I worked on  a ranch in Wyoming. Some of the time, I had to ride fence line as part of my job. On one occasion, the chap I was with decided to not heed protocol and just decided to grab onto both ends of a broken fence wire. It was early morning and things were wet as was his gloves. After considerable cussing and bitching, he connected the grounding wire. The resulting shock was substantial. It took him to his knees and left him shaking for a few minutes.
   I was told that this was a thing called ground potential. Later in life I learned the why and what about it. I was told it can be nothing to thousands of volts potential. May not be much current but then what the hell. A ground wire strung log distance and a buried radiator could have one hell of a difference of charge.
thay
Belfior
Quote from: Thaelin on August 22, 2018, 01:00:17 AM
thay
Same thing with the natural gas pipeline. They are heavily grounded to avoid sparking. I think they still debate if the current is inducted from a changing or moving earth's magneric field. The field is not very strong, but over hundreds of miles it accumulates.
My own WTF story is from my parents place. 4 car tyres piled up and the plastic hub caps on top of the pile. Caps had a round steel wire for fastening. My dad touched a hub cap and got shocked. He cursed and pulled away. He went back and touched a cap and was jolted again. Then he thought I had electrified the tyres and he got mad at me. We then inspected the tyres and found nothing. 4 tyres on wooden floor. You only got shocked from the hub caps. If you think about it it was 4 alloy rims insulated by the rubber. Then a plastic cap with a wire (antenna?) and you got an exfect
