Aetheric transformer/inductor
Started by aether22, July 23, 2018, 09:06:04 PM
aussiebattler
I would be very wary of replicating these circuits. I ran one thru my recently acquired app "Testing for shonky circuits" and it came up with a red alert. It seems that if one of the aethers escapes and collides with a quasar a catastrophic volcanic like eruption follows. Apparently this leads to millions of electrons leaking  out everywhere causing disastrous results to all electronic devices in the vicinity. I also have it on good authority that the contaminated electrons are carcinogenic. This of course would require the experimenter to wear a full body suit for personal protection. In summary the circuits  could be replicated providing appropriate precautions are taken including the installation of fire extinguishers and taking out suitable insurance covering fire, explosion, and personal injury.
aether22
Quote from: aussiebattler on July 24, 2018, 09:37:39 PM
Ok, you are joking and doing it poorly, firstly what I am saying indeed does sound like gobbledygook and nonsense to you just as
explaining electric circuits with electrons and atoms and emf would sound like so much nonsense to someone before all this science was developed.
Next, there is some danger but not much.  One example of danger, though this came from just a TV, is the mythic explosion that
apparently occured according To Steven Marks, when a boy was watching TV and the field around the ferrite yolk collapsed, well I
have created similar dynamic fields and it kinda adds up to me, the aether moves within such rings and it can come to a collapse
and in doing to it evolves a lot of aetheric energy.
I also felt the surf board like movements of the donut that SM mentioned, this does occur, though this was very very early (roughly
7 years ago) once i had gained elementary success with feeling the energy, it was like in the first week probably, so it verifies what
he did IMO.
But that is an example of possible danger.  albeit only from a very specific design, and unlikely overall, but Norm Wootan with  the
MRA and sometimes with locked motors sometimes would break a magnetic circuit and a pulse that defies conventional physics
would be released, but this was not as dangerous as the energy wave that IIRC killed the boy watching TV.
I have also heard that someone made one of Paul Pantone's GEET's and it exploded massively, that device causes transmutation and
not NOT conventional, it is aetheric.
Still, such things are RARE!
But go on, joke and ignore because that will add so much to Free Energy research.
aether22
Quote from: TinselKoala on July 25, 2018, 08:49:54 AM
So, presumably YOU yourself can feel this energy you are talking about, coming from your designs, coils or images. So I propose a
test. We will take one of your designs, coils or images, that you can feel, and we will put it into a box of some kind. We will have five
other identical boxes with inert contents. Let's use an image, since it won't be making noise or ordinary vibrations that might give it
away.  I'll mix up the six boxes, and you can tell me which one contains your energy-emanating image. We will repeat the 6-box test
ten times, and if you are able to correctly identify the box with your thing in it 8 times out of the ten trials... you win, and I'll write a
full report and get it published in a real journal. If not... I get your thousand dollars. Before we start, you provide proof of your
thousand dollars by putting it in escrow with a trusted third party (Chet? Wesley?).
Does that sound fair to you?  Since you yourself will be providing the image (or coil or device) and you yourself know already that
you yourself can feel its energy... this method eliminates all third-party variables. We didn't build the device wrong, whether or not
we are sensitive doesn't matter, there can be no excuses of that nature and you yourself will be the primary judge of whether or not
you yourself can feel this energy. 8 out of 10 trials with six boxes.... should be easy for you.
That sounds mostly fine, but there are some issues.
As for the $1k, I am unemployed, I do have the money actually and more put aside, but my [/size]mortgage just rolled over
(fixed term ended) so I put my money in there, while I can get it out of the floating portion, the plan was to pay it down from
where it is and I am reticent to push it back up, though I could...  And in addition there will be fees for moving it out of
New Zealand which I would not be happy about losing, probable exchange losses and then I am trusting someone, though
I do have a strongly positive opinion of Chet the whole point of putting up the money is based on the idea that I am not trusted
and he is, why do you consider my word and reputation is not enough?  I have been in this field my whole life and welching on
such would not be good.[/font]
Also I am in New Zealand and it would cost more than that for us to get in the same place for the test unless you were ok for it
to be performed here with people I can find and videoed...
I actually have not done much in the way of such tests, but I am rather confident I could do that, even though I don't generally
like such tests since the energy can be consciously effected, so there is room for the test to be effected, I really don't like such
tests in general, but I am 98% confident I'd be successful.
So my counter offer to your plan.
I make 2 different images, one that produces energy and one that doesn't, these could look near identical.
I then walk the streets of my town maybe a town within an hours drive and I ask strangers to see if they feel energy above
either image.
Then if people don't select the active image, or if a coil, the active coil, then I pay you the $1k.
Or, how about this...  as anything that involves me feeling energy locally and setting things up will be prone to be suspected
of being faked, maybe other could just see if they feel energy...
Why not just try it, and get some friends to do so?
I could make a similar looking design, indeed I could hide from you which one is active and which isn't.
If you or people you and others show it to cannot feel there is energy or pick the wrong one, then I will accept I have lost and
pay you the money, which I can get out, but I consider the chance of having to pay it out to be less than 1%.
I guess the other thing is we could do a multi part thing, first I prove that I and other locally can feel the energy, providing as
compelling proof as I can by selecting strangers.
And then you do tests there.
Or, and I know this sounds crazy, just try it!   The sensations are not subtle for long for a good % of people, the energy can be
very intense and quite shocking.
This is not all super subtle stuff.
In addition people, strangers with no knowledge have felt energy from coils, even when hidden!  It hasn't happened often, but
it HAS happened more than once!
Oh, and if you insist it MUST be on your conditions (yes, all of them), then I accept, but you must pay for the costs of travel
and the money is held in NZD by a 3rd party in person so there are no losses from sending the money.
whoever travels, me there or you here, unless by some long shot you are a New Zealander.
BTW attached is the latest image, just put it on your screen, feel in the space infront of the image, try putting your hand on
the screen covering the image, slowly move you hand back 2 feel feeling for any sensation, move your hand back in, keep this
up for 2 minutes, then just spend a few moments feeling if freestyle.   There is roughly a 50% chance you will feel something.
And a 25% chance it will be notable/intense.
Acca
Russian TV's where number one cause of fires in homes in Russian and Poland in the 1970's to 1990's. TV's did implode due to the picture tube being a vacuum for the electron gun to work. Crappy builds of electronics contributed   to that effect..
Ferrite ring was to blame as it overheated the thin neck (yoke coil)... In some circumstances the yoke went in to a resonant state and exploded. Question is why ?  Iron bonds broke went in powder and the powder was the source of fuel to burn down the apartment.  Heat was like 1800 deg.  Iron powder ignites with with a match.
There was a re-formulation of chemistry of the ferrite yoke.. and it stopped the TV fires...
Two tesla coils will make a superposition wave and destabilize atomic bonds if they are in resonance with an electrostatic field from a high voltage flyback transformer like on the back of the Russian TV's..
Try it it works, and aether may contribute to that effect..
As you are fascinating bringing up these effects of the aether,  like to here more on the effects, like on the helix wound  "smith coils"..
Acca..
@SEYCHELLES:  As you can see, oversized images screw up the thread formatting and make the "reply" buttons and other buttons scroll off the screen to the right. Please limit images to 1024 pixels or less horizontally to avoid this issue.
@Aether22:
1. You really should not be putting money at risk unless you actually have the money to risk. This is why I mentioned the escrow as a condition to start. If you really don't have the money... then you shouldn't be gambling. Or rather, risking, even a one percent chance, that you might lose money you cannot afford to lose.
2. Your location in New Zealand should not be a problem. Please note that there is an active skeptic's society in NZ, with chapters or members in the major cities. I would accept the results of a properly blinded test designed and administered by some members of this society, along the lines of what I have suggested above. They know how to do properly blinded and controlled tests and they understand the statistics of randomization and regression to the mean.
You might even like to attend some of their "pub" meetings in order to get to know them and see how they think... and what they think about your claims.
http://skeptics.nz/
If you have a problem with skeptics in a society, let me know and I'll get in touch with some people at the University of Auckland or Christchurch Polytechnic Institute of Technology or some other university near you and we can try to arrange a fair test there.
Meanwhile, you might like to research the topic of "blinding" in psychophysical testing, so you can understand why the kinds of tests you have proposed aren't really objective, fair or suitable.
3. The money is also no problem. Surely you have no-kill animal shelters, dog/cat spay/neuter programs, or similar programs that care for dogs and other pets that need help. If you lose, I will accept as payment, proof of a confirmed 1000 NZD donation to such an organization. Just post a photo of the receipt for the donation. If you lose, that is. I have no desire to profit personally in the case of your loss, but I definitely do think that people who make such offers and claims should be challenged to make them good.
To be clear, what we would be testing is your assertion that you can yourself detect the subtle energy (or whatever you like to name it) emanating from your diagrams. This is a first pass at a basic test. If you yourself cannot reliably detect which box contains your diagram, then there is something wrong with your claim. Either there is no energy to be detected, or you cannot detect it, or the box blocks detection somehow, or some combination of these factors. Further, more refined testing would tease out the finer facts. If on the other hand you _can_ reliably detect the location of the concealed diagram, then you have a start of something really big -- if further testing confirms the results of this preliminary test.
