Aetheric transformer/inductor
Started by aether22, July 23, 2018, 09:06:04 PM
ramset
YeashI hope Stefan fixes this some day
I realy do hope so ...are we to the next page yet ?
Thanks Grandma
aether22
Well, that did it.
To celebrate, I will tell you what I have just discovered...
I believe it explains the shape of flying saucers...
So first a little background, a circle will tend to aetherically project into a cylinder...  Which is to say the circular form is recreated into the 3rd dimension.
If there is an energy that this cylinder taps into, if the intensity of this energy varies over the length of the cylinder, it will pull energy to the point of highest intensity.
So I have found for instance that if you have a coil (circular or cylindrical) that is the right number of turns to tap into magnetism (20 or 20.25) that if there is a magnetic gradient, you will induce an aether flow in the coil.
|||||||||- coil
N
S  N
    S   N
         S   N
              S
The magnets be being stronger or closer to one end creates asymmetry...
To do this you also need an aetheric short circuit, this can come from twisting wire in a simple twist knot (like the first knot you use to tie your shoes). which aetherically acts for many energies a lot like a ring or cylinder.
But look at the Russian coil of a conical shape posted earlier by Tynoo, this would meet this criteria, it only needs to be wound on a cylinder, or to have some turns twisted as I explained to create a closed loop.
But this would also explain the conical shape of a flying saucer, I found that an alternative to making the energy more intense was simply to contain more energy at the coil, but making the right changes the coil could project a conical field and this naturally pulls energy to the widest point.
But as this would be working based on the internal energy of the form, you would ant to put a lot of energy into the form, but many accounts have the saucer with a central coil pumping intense energy.
This also makes sense of Otis T. Carr's Utron.
So, to clarify, you need either...
Some form of closed loop circle/cylinder...
And an energy with an intensity gradient over the length of that cylinder/projection (consider Paul Pantone's GEET with tubes with heat applied).
Or you need something with a conical form (physical, or a continued projection) which can have a constant energy, the gradient is created by the shape.
The conical one is a bit funny as 2 things works in opposition, the metal actually focuses it's effect towards the top, but the energy inside focuses towards the widest point.
This also explains Tesla's finding conical coils to be of interest.
But don't get hung up on any specific implementation, the principle is closed loop/cylinder plus energy gradient along length.
This also would impact on Walter Russell's conical vorticies.
Tinsel Koala, sorry I have simply not put doing a new proper test as a high enough priority to actually do it.
I have already produced evidence that moves it into the realm of very high probability it is real (I also presented conclusive pre-existing testimonial evidence), and I am not trying to seek some "skeptic approved" verified status, quite the opposite.
I only want to seek the attention of those who have an open mind and a tendency to experiment and honestly what I have presented should be enough for such a person to take interest.
For anyone who is believes I operate in bad faith or who thinks me crazy, no amount of convincing is likely to turn them into a productive experimenter IMO, someone operating from that level of closed mindedness and cynicism is unsuited.   Still, I will do a test with 10 cups and film it and do a number of rounds assuming the rounds are successful.
P.S.  I counted and each page has 21 posts, this is including the Ad posts, length of post does not not matter.
aether22
Ok, my recent discovery (well, it has been reinforced, I got the first hints a few years ago) has been that the bandwidth of the aetheric energy is important.
One specific and simple way to increase the bandwidth has become increasingly apparent.  Also relivant is that this employs what i term foreign conduction, when an energy flows through a material it was not liberated from, it moves much faster an energy native to that material.
Anyway, what I have found is that different metals used for the conductors of a device (actually, electrical energy does not have to be conducted through all of them, as long as aetheric energy is) can increase the bandwidth of the aetheric energy, and let's look at this from a historical perspective.
So Let's consider Louis Rota, you might not know much about him, but he achieved antigravity, and he achieved Free Energy, this was by burying bundled slabs of different metals, and conducting this compound aetheric energy for various uses.
Another early example is Keely, he used wire consisting of a core of one metal with to outer layers of other metals, I think Platinum was one of them, but the point is this might has been ideal, sure, but it is not IMO necessary to use anything so expensive, the point is a tri-metal wire of key.
Then yesterday for the first time every I came across something I had missed hearing about before, Tesla's Tri-metal generator, it consists of Aluminium, Iron and wire.
Now let's consider Stubblefield, like ROTA he buried metals, but just 2, copper and iron, and with this he lit a carbon (another conductor, plus plasma, a 4th).
Now to be clear I am not saying that anything more that one material is used in a circuit Free Energy results, rather what I am saying is that by using different metals, if the design is suitably engaging the aether and the connections support aether flowing in the circuit effectively, and if other components are present, then the metals used can help widen the bandwidth.
I also found that winding a wire many times around another wire and having then connect in parallel creates a high bandwidth effect even with a single metal as used by Markovitch.   And Keely used different length wires to tune into a high bandwidth.  And the loads used also contribute, again I would use John Hutchison as an example.   Tesla's Pancake coil also resonates with a wide range of energies.
Another example of this multi metal thing is Lakhovsky's MWO, the different rings were made of different metals.
I have also in the past identified a lot of evidence that some designs pull energy from either air, water, glass or some transparent material, Indeed I think Tesla's glass bottle based capacitors used at one point might have had an impact in some key results he got.
Another example is Les Brown, he used a pancake spiral, wound out of wool IIRC, and when he connected this to a Copper wire he got a huge discharge of energy that threw him violently across the room in his pyramid shaped home.
Hendershot combining his coil (copper) and capacitor (Aluminium) and coffee can (steel) would also fit!
We cold look at Swiss ML's use of Aluminium cans along with iron wire in one part...
Or what about Dotto, with his Copper ring with an allow segment.
Or Searl with concentric ring of different materials!
I have found that a Zinc wire can easily be made from cutting the Zinc can from a "heavy duty"  AA or other sized cheap battery.
I bought some Aluminium wire used for welding affordably, and picked up some even cheaper copper coated steel wire, sure enough these things increase the energy.    I will pick up some tinned copper wire also.  I don't think 3 is the limit, I think 2 works, and 4 works better.
Batteries, especially mixing different types in parallel/series might also increase the range of energies, but again with electrical circuits i recommend connecting the negative end of an otherwise unconnected battery.
I am not saying that this is a necessary condition, and it certainly isn't a sufficient condition but it helps, and it is easy.  Add in a carbon arc lamp and a Piezo buzzer, maybe a motor and or something HV as "loads" and the bandwidth of the energy will be further increased.
But this only increases the bandwidth of the aetheric functionality if propperly implemented buy itself it won't produce Free Energy or anything even interesting, this works on aetheric,not electrical current.
aether22
Oh, and Hans Coler used Silver and Iron in series with copper wire.
It is also worth noting that Telegraph operators, sometimes used grounds of different metals and a single wire, because the grounds used different metals a voltage was created (earth batteries), but many of these telegraphs demonstrated Free Energy and also signals over broken wires and other indications of aetheric energy, well the source of the aether is not unclear, that is the telluric currents in the earth, but the different metals helps to increase the energy bandwidth.
Tesla also used an elaborate grounding system which used I believe both steel and copper an minimum.
He also used an aluminium tube mentioned in his magnifying transformer patent connecting between the coil and the upper electrodes.
Steven Marks used copper and iron wire.
Hubbard, Perrigo and Bedini used iron wires/nails/welding rods as cores (more suited to coupling to a wire I think), the energy from this might have coupled into the copper wires, as might really and open magnetic circuit device (Adams motor and many others), including U shaped magnetic cores (used by too many to list, but included Moray).
Ed Grey used a carbon block resistor, as well as the air arc, not sure what he used for his screen around the tube, but this might have been a 3rd.
So now, going back to my original proposed coil, add in other wires, include the negative pole of a second battery (split the positive ad Ed Gray said (don't connect it)).
Also Stiffler with a super low voltage current from his Thermal Magnetic Battery TMB that despite it's low voltage would have a bright blue spark of not insignificant length on breaking a circuit!   not only might the energy of the plates (Tin) be added, but the ferrite magnets which the current somehow passed through (along with glad wrap and cardboard/balsa).
Also Sweet used an Aluminium cage, the energy of which could have entered the coils along with the energy of the ferrite magnet.
Indeed it might interestingly be fewer devices that just used copper and closed magnetic circuits than those that plausibly implemented this principle on mixed energies.  Certainly with the early pioneers, multi metals was abundantly clear, Rota, Stubblefield and Tesla, it was quite marked!
