Homopolar generator idea
Started by Antiproduct, October 01, 2018, 03:55:41 PM
shylo
In the video what would be the result if you spin the stator and magnet?
One in both the same direction, the other in opposite directions?
I would think the voltage would double.
artv
F6FLT
Quote from: shylo on March 01, 2019, 04:54:39 AM
artv
agreed.
The answer was above. Here are all cases:
1. Disc rotating + stator at rest: voltage
2. Disc at rest + "stator" rotating : voltage
3. Disc rotating + "stator" rotating in the same direction : zero voltage (due to no relative speed)
4. Disc rotating + "stator" rotating in the opposite direction : twice the voltage (due to twice the relative speed)
In any case, magnet rotating or not rotating: same effect
If case 3 provided a voltage, you could charge a capacitor connected between the axle and the rim of a Faraday disk and rotating with it. I did this experiment to be sure: no voltage.
I rotated the disc with the capacitor for a while, then I accelerated the motor, which disconnected the capacitor by centrifugal force on the rim contact. But at the arrival after stopping the motor, the capacitor was not charged!
seaad
Quote from: F6FLT on March 01, 2019, 09:26:39 AM
Right motor is constantly spinning. Readings center to rim.
Left motor: magnet rotating + or -,
or not rotating at all: same effect
F6FLT
Quote from: seaad on March 01, 2019, 11:35:00 AM
Never believe without verification!   ;)
Good point, and nice demonstration!
shylo
So the stator has to see the disc in motion,and as long as a magnetic field is present a voltage is produced.
If you put on a second stator,could you collect double the voltage?
Or stators on both sides of the disc,reverse polarity but still a voltage?
artv
