frequencies and claimed associations
Started by Grumpy, December 06, 2006, 07:14:31 PM
starcruiser
Quote from: Grumpy on December 06, 2006, 09:34:17 PM
QuoteThe frequencies- 46.98, 62.64, and 70.47 when mixed.
70.47-46.98= 23.49
62.64-46.98= 15.66
70.47-15.66= 54.81
62.64-23.49= 39.15
70.47-39.15= 31.32
70.47-62.64= 7.83
62.64-54.81= 7.83
23.49-15.66= 7.83
54.81-46.98= 7.83
39.15-31.32= 7.83
31.32-23.49= 7.83
15.66-07.83= 7.83
46.98-39.15= 7.83
Jeff
well, isn't that interesting...we got work to do
if earth resonant freq entrains collector that has same 7.83 heterodyne freq...might be very powerful effect
(EDIT)
46.98 Hz, 62.64Hz, and 70.47 Hz are the 3-6-9 series of 7.83 Hz - perhaps Tesla's 3-6-9
(EDIT 2)
In mystic teachings, 46.98, 62.64, and 70.47 form what is called a Yod (10th Hebrew letter which means "Finger of YHWH")
"What exactly is a Yod? It is an isosceles triangle resulting from two quincunxes (at 150 degrees each) linking two tile planets (60 degrees apart) to a third. When dealing with planets, the degrees that make up this configuration must be concisely 150/150/60 degrees apart but in galactic space, a quincunx can have up to 8 degrees of variation and a tile up to three. By definition, a Yod is the handiwork of indefinable and omnipresent forces of fate that can only manifest through unconstrained stress."
This combination is also referred to as the "finger of God" in this reference:
QuoteIn the lower audible range there is a group of notes in a Ã,“yodÃ,” or quincunx pattern, 46.98 cps and the Ã,“finger of GodÃ,” notes of 62.64 and 70.47 cps. Although not fully researched, these notes together have a strange effect mentioned but not described by gravity and acoustics researchers.
Caution is advised until further research is done, although experimentation to date indicates that the effects may be due to unusual effects on the human auditory perception system, which seems to be sensitive to these harmonics. The significant point is that one of the notes is in fairly exact octave relationship to the Schumann Resonance, and is thus a three-octave overtone.
Another reference:
Quote50-60 Documented negative effects (associated with these three frequencies) too numerous to mention. There is no correlation given with signal strength or modality used, i.e. audio-visual, EMFmagnetic, electrostatic, gravitic.
Perhaps I will try these three frequencies - with coils positioned at 150, 300, and 360 degrees.
Which references did you read these from? Pleae post the links if possible. I would like to read these as well.
Carl
Grumpy
Google a string of words form the quotes (they are direct quotes) and it will pull up the link.
        -Frank Edwards
Spherenot
Upper Left: 7.83 Hz (one second)
Upper Right: 5007.83 Hz and 5000.00 Hz combined (one second)
Lower Left: 70.47 Hz, 62.64 Hz, and 46.98 Hz combined (one second)
Lower Right: 5070.47 Hz, 5062.64 Hz, and 5046.98 Hz combined (one second)
I do not have access to an oscilloscope, (which is why I need detailed plans before I build any coils.  I can not test any coils but I can follow plans.)
But I do have a computer.  This is the only way that I can contribute,... so far.
Grumpy
Great Spherenot,
Lower Left: 70.47 Hz, 62.64 Hz, and 46.98 Hz combined looks interesting - kinda hashy - os this because of a view setting (scale, etc)?
Can you shift the phase between them like this:
46.98 at zero
62.64 at 60 degrees behind
70.47 at 210 degrees behind
        -Frank Edwards
Spherenot
Quote from: Grumpy on December 07, 2006, 06:48:29 PM
...kinda hashy - is this because of a view setting (scale, etc)?
Can you shift the phase between them...
Yes, it is because of the view setting.  The smaller green scale, (zoom-in just below the graph,) actually looks smoother.
Sorry, no, I can not phase shift with this, "NCH Tone Generator."
