Zero and Q device
Started by v8karlo, January 04, 2019, 11:18:12 PM
v8karlo
Quote from: citfta on January 13, 2019, 07:52:09 AM
You do NOT understand the circuit you have been posting about.  Anyone with just a very basic understanding of electronics will tell you that the current through the capacitors is not constant.  In this circuit the current is constantly CHANGING.  If the current through the caps was constant the would mean the caps were BAD.  Good caps charge up and when they are charged the current drops to ZERO except for whatever leakage current there might be.
Hehe,
Capacitors are not linear. But, you missed everything here. Everything.
I am not talking about process of charging.
In a capacitor 22uF you can not put more charges than that capacity can hold at given voltage.
It changes with voltage. So with voltage you change power in capacitor, but you can't change capacity. Capacity is fixed, constant.
Voltage is factor which push more charges into capacitor.
So you have threshold above which you can not go with 90V.
If you have 175V in that capacitor it can hold more charges (power) than same capacitor at 90V, but still it is limited with capacity of 22uF.Capacity of 22uF does not change, it is constant!!!With voltage you regulate how much power capacitor can store.Capacitor 22uF at 175V holds more power than capacitor 22uF at 90V.
So, the power is what we are talking about here which changes with voltage in caps. Capacity stays the same.
Current is the speed how fast cap will charge to some voltage for given capacity.
Less current - it will take more time for cap to charge to given voltage at given capacity.
More current - it will take less time for cap to charge to given voltage at given capacity.
You are not only missing the point, you probably missed entire forum.
And when you put amp meter on that line it won't show how capacitors are charging.
It will show constant value. That is how you measure current.
And the current trough L1 is same value as the current trough 3 caps. It is the same current.
I presume you know how amp meter works?
Quote from: citfta on January 13, 2019, 07:52:09 AMThis will be my last post here because there is no reason for me to waste any more time trying to help you.
You are not helping me at all.
You never did. From the beginning.
I will be glad for you not to post here.
NickZ
Quote from: v8karlo on January 13, 2019, 04:39:41 AM
Put 2 Zero circuits with inputs in opposite phases.
Combine their outputs into one.
You have full cycle output.
   Karlo:   I am using a crystal oscillator which is connected to a "diode loop", pictured below.
   The diode loop allows for both positive and negative pulses from the oscillator to be utilized by the output.
The IN4148 diodes are switching diodes, and help to increase the voltage, similar to what your capacitors are doing. The two leds bulbs that are in the middle of the diode loop are 120v 8w AC bulbs, and can light fairly bright, although not as bright as when connected to the grid. Each diode added to the loop is increasing the output voltage. Each bulb is equivalent of a 60w incandescent bulb.
  Possibly the same type of diode loop and led bulbs can be used on your type of oscillator or device to allow both polarities (full sine wave) to be used, which may give a higher bulb brightness (lumin levels) than what incandescent bulbs will do on limited input sources.
   The oscillator, (or signal generator) is on the left side of the diagram, cap C1 and C2 help to separate the polarities from the source pulses, along with the series connected twin diode loops.
   If you have questions, just let me know.
                                                              NickZ
v8karlo
Quote from: NickZ on January 13, 2019, 08:46:46 AM
I did try to utilize both polarities in one circuit, but I failed. What I did is 2 Zero in opposite phases sharing 1 cap CZero.
It worked but it was too complicated.
Later I did 2 Zero circuits separated, with inputs in opposite phases.
I merged output. Minus to minus. Plus to plus.
And I got full wave output.
I know what are you trying to tell me, I tried, but I failed to do it in 1 circuit.
Maybe it can be done.
Can you send me link of that video to see what you did?
