How to make an anti-gravity barrier
Started by geptole, March 04, 2019, 04:54:39 AM
geptole
(this has been translated with google)
These are simply 2 rotation axes placed perpendicular to each other (a carpenter would say "in team")
The 2 imaginary axes must intersect perfectly otherwise we get dynamic imbalances that are not going well.
If 2 axes of rotation are required, then 2 electric motors are required.
To distinguish them in the drawing one engine is green and the other is pink.
The purpose of the pink engine is to generate a very strong gyroscopic effect, so strong as to be almost inflexible.
The purpose of the green engine is to quickly rotate the rotation axis produced by the pink engine.
The effort to make the green engine is remarkable because the gyroscopic effect generated by the pink engine is remarkable.
The pink engine has to do 40,000 rpm, instead the green motor has to do 20,000 rpm.
We must remember that the gyroscopic effect has the tendency to keep the axis of rotation fixed in space.
The torque generated by the green engine should generate heat or potential energy, instead it does not generate any of the two forms of energy, so it seems that the famous law of energy conservation is not respected.
In fact: in order for the law of conservation to be respected, it must necessarily happen that the ("space_time") that is above the pink motor must start to turn on itself and then accelerate with a rotary motion.
This creates an barrier anti-gravity that prevents gravity from passing, so one kilogram placed on a scale weighs will be less than 9.8 newtons.
The more we increase the speed of the rotation axis A, the more the antigravity barrier becomes efficient
Note: you should not exaggerate to shield the gravity too much because the excessive shielding of the gravity could provoke a tearing of the ("space_time"), the laceration of the ("space_time") could provoke a gigantic explosion.
Low-Q
What makes you think this rotating discs will "produce" zero gravity? What theory supports this idea?
Do you have a legit documentation that supports this?
Vidar
geptole
I'm not thinking zero gravity, I'm thinking almost zero gravity.
The theory is supported by the law of energy conservation.
Since the green engine works like a pack beast because it fights against the gyro effect, somewhere energy must end.
With the exception of internal frictions, there is no heat production and there is also no increase in potential energy, so if the famous law of conservation of energy must be respected, it must necessarily begin to rotate the ("space_time"), but by rotating the ("space_time") happens that ("space_time") expands itself, but if ("space_time") expands itsself the gravity of the planet Earth is partially shielded.
Now do you have understood ?
(I apologize for grammatical errors but I am Italian)
F6FLT
Why "The pink engine has to do 40,000 rpm, instead the green motor has to do 20,000 rpm"?
Please show us the equations.
There can be no "anti-gravity barrier that prevents gravity from passing" because gravity is a deformation of space-time, there is no gravity flow (only gravity waves, irrelevant here). If you think relativity is no longer valid, how do you explain the extension of the lifetime of radioactive particles accelerated to a speed close to that of light?
Low-Q
Quote from: geptole on March 04, 2019, 01:49:36 PM
The gyro effect does not defeat gravity. It appears to me that you assume it does, but it doesn't.
I will also ask the same question as F6FLT; Why exactly 20k and 40k rpm?
Vidar
