hammerFall gravity powered generator
Started by burnit0017, July 22, 2019, 09:59:18 AM
kajunbee
Is the spread on your paddles still 60 degrees. If so do you see a problem with going to 30 degrees spread. If I'm thinking correctly this should give a 1 thru 6 on first half revolution. Then start back to 1 thru 6 on second half of revolution.  This should allow you to keep both paddles. In my mind it would look like two half spirals. But I'm not sure how this will effect the stroke on your lever arms. You may have to lengthen the levers and cut down the length of your paddles to allow for the shorter stroke. Not sure.
kajunbee
It would also allow you to place your weight further out on end of levers because of the gain in mechanical advantage on your shorter paddles.
burnit0017
Hi, interesting suggestions, thanks, nice to have options. Before I do anymore changes I should test it under load. Thanks again
burnit0017
Conservation of energy maybe a reason why this project could fail.
