Mgnetic shield?
Started by telecom, July 30, 2019, 02:47:16 PM
gyulasun
Please copy and past the text from the first part you do not understand.
Re the 2nd part: it can only be verified by actual tests and with magnet sizes and ratios Floor wrote.
Gyula
telecom
This is what I don't understand:
But the orientation / direction of the shield magnet is 90 degrees off.
If you rotated it so that its broad faces were up and down that would be
one of the designs I have presented.  But I don't recommend that.
                           Because,.....
1. with the magnet shapes you are using,  the sliding magnets
would be too far apart, even when they are pushed toward each other.
2. You would be shielding two magnets with just a single one.
If he means placing the shielding magnet perpendicular to the repelling magnets,
this will not work - it will affect the neutralization + greatly diminish the repelling force.
Or something else?
Clear drawing is needed to understand clearly.
In terms of the second part, I agree that there is nothing better than the real test.
The exact drawing with dimensions will also be helpful.
Or even better, a working prototype, rather than teachings.
telecom
Just to clarify why I think inserting of the array shield is not going to work.
Both attraction and repelling should be exactly equal for the rack and pinion connected magnets.
In our case, from the left, repelling is 1.5 units, while from the right, the attraction, is only .5 units.
So much for the "teachings".
gyulasun
Quote from: telecom on August 01, 2019, 11:42:11 AM
Or something else?
Yes, he meant perpendicular as you did and indeed the distance between the two facing (repel) magnets would be
too high to make the setup useful. But he did show this variation in a separate video, just to demonstrate that the
shield magnet can be moved in or out with very little input force with that orientation, that was the point:
https://www.dailymotion.com/video/x59r978  and as he wrote to citfta he did not recommend it due to the big distances.
You can see magnet sizes Floor used earlier in 2017 for tests if you look for it:
https://overunity.com/17070/all-magnet-motor-td-based/msg502026/#msg502026
and read what Floor suggested to citfta
https://overunity.com/16954/magnets-motion-and-measurement/msg537962/#msg537962
but those are for citfta setup...
Nobody will show to anyone a working setup and IMHO it is the principle which is important and Floor did explain it.
Regarding your 1.5 vs 0.5 unit difference instead of equal attract and repel forces, Floor mentioned differences
(due to manufacture or abuse) in magnet strengths to consider and selecting them if needed.
Good luck,
Gyula
telecom
Quote from: gyulasun on August 01, 2019, 05:19:44 PM
Yes , I tried it myself - it slides well, except it doesn't provide any shielding.
He suggested using double sized magnets for the shield.
The problem is, they will be overpowered at the close distances by the
repelling magnets because the distance between them will be smaller than
between the shielding magnets.
I would gladly did. In fact, there is something interesting I've noticed when reading
a magnet patent, will post on it later.
This was referring to the actual sizes of the shield magnets. He went around it by doubling the sizes, but it has another pitfall, as described above.
Looking forward to see how this will be implemented by citfta.
