Creating TPU Steven_Mark
Started by crashangel, September 06, 2019, 02:25:16 AM
Toolofcortex
The core will be composed of bifilar wound magnetic alloy, wich should be cheap and abundant.
A standing wave is setup for there to be nodes of zero current.
The wavelength should be small to maximize node sites.
The wavelength should be a multiple of 7.8hz, but with such high multiples does precision even matter?
Then the rest is controlled by a master algorithm that will mine the frequencies.
With many many coils.
It's the same thing as bitcoin but even more venture.
Raycathode
Have you bothered to look at SM's original there is nothing in it ! so where is all your stuff hidden ?
Toolofcortex
I don't know what you mean and no I have not bothered.
There is 13 years of posting on the TPU.
kajunbee
Don't worry Smoky, our paths run parralel. I may zig when I should of zagged sometimes. But still headed the same direction.
sm0ky2
None of our technology is ours, save that which was derived in the
last century.
All else was deciphered from ancient texts and reverse engineered
from that which we found.
The Crooke who stole radiology and claimed it to be his own invention.
or the thousands of early patents that gave innumerable wealth to families.
Information was coming in so fast we didn't know what to do with it.
Much of which has sat on shelves, still undeciphered to this day.
Stolen, all of it. These inventors didn't even know how much of it worked.
The physics to represent much of the inherited technology did not yet exist.
We still don't have a full understanding of these machines today,
even when we build and test them.
Why is this relevant?
I was educated as an electronics/computer engineer, specializing in robots.
As an entrepreneur I created a robotics company. They have fascinated me
since the robots of science fiction I read about as a child.
As a historian, I had a chance to observe fist-hand a robotic mechanism from
shortly after the collapse of the Bronze Age, in a time when everything was
supposed to be "dark".
Among many artistic city scene drawings showing illuminated buildings and street lights
Lighthouses, lighttowers on hilltops and major junctions, lamps in buildings, etc.
Images of people, do detailed it could not have been drawn by hand.
(determined to be an unknown magnetic imaging technology)
Was an array of mechanisms. Mostly physically mechanical, having drive wheels or
cranks to turn,gears,  weights and pulleys, etc.
There was one that stood out. It looked like a man, or rather an armored knight.
This machine had no external cranks no internal weights, no visible drive mechanism.
At least at first sight.... Being an engineer , I had no choice but to examine this mechine
in an attempt to figure out how/what it did.
Each system of the robot was broken down into specific drivetrains internally.
But otherwise resembled a grandfather clock.
While some of the gears shared common fixed axles, it was clear that they were not
interconnected, and that the gear systems each operated independently with no common
drive mechanism, flywheel, etc.
Each system was driven independently. And operated a physical motion of each of the
legs, arms, hands, head, torso, and various mechanisms, most of which had been removed or
destroyed long ago.
What was curious was that each drivetrain terminated with a small gear driving a large gear
Adjacent to the small gear was a curved strip of metal that resembles that inside a thermostat
or mechanical thermometer (but only one strip not a bi-metal)
The strip was connnected at one end to an antenna that protruded externally near the top of
the robot. Each antenna was of a different size.
And not physically connected internally, but rather had a separation material of unknown
composition between the receiving antenna and its outer casing.
My conclusion at the time was that each system was operated somehow by a specific frequency
radio transmission.
The control panel, which was stationary and somehow powered (by the building!?!)
was very similar to the stiffler circuit but had glass bulb like pieces that looked like an
oversized vacuum tube, but did not have internal metal parts. (maybe once held a gas?)
My point is, the technology we are talking about in this thread was being used thousands of years
before we got here. We are children playing in the dark....
Look at the rooftops downtown anywhere....
Go to your capitol or post office, local college, or the town's original bank.....
Look at the historic district wherever you happen to live....
Look at the objects on the roof. The "vases" or "ornaments" filled with a strange substance....
electronically wired into the metal-frame of the concrete or brick structure.
Realize that that circuit connects to earth ground some hundreds of feet below in the
(now buried) 70-ft "basement".....
Don't live near a city? That's ok, drive down any federal highway and look at the first town you see.
It's all the same all over the world.
We don't understand the technology, but it is clear that they had it.
we can't even make that type of stuff.
Look at our fences, look at our walls, and look at theirs.
Everything was carefully engineered to vibrate at a natural frequency.
Take a piece of their technology and remove the paint we put on top
And the thing vibrates on its' own.
The fences, gates, candelabra, steeples vibrate when they are not painted!!!
The ones that are made of more than one type of metal emit emf when they vibrate.
Another receiver of the same dimensions nearby will synch up like a pair of metronomes.
(even when the particular shape may differ!)
We have all seen an overhang vibrate violently in the wind, or a tarp flap so hard it rips itself.
There are constant energies and motion all around us. Some we see, some we feel, some we
hear, some are radio or emf, and some we don't detect at all. But they are there, for us to use,
for free.
Iron vibrating next to copper
What happens?
The earth places a tiny magnetic field in the iron.
The motion induces a field in the copper
The continued vibration amplifies the emf in both.
This works in reverse. An electrical oscillation in the piece of copper causes a physical vibration
in the iron.
The continued oscillation amplifies the physical vibration.
This is how the ancient robot functioned.
Just like the TPU.
People get lost on the source of SM's impulse.
Put that on hold, that's the free energy.
Learn the device, learn how to amplify the signal. Maybe start with a signal generator
and coils you can control the parameters.
You can use an old radio trick to tune your coils, by having a connection point on a set screw.
And sand the outer edge of the coil in a strip down the length of the coil.
This allows you to adjust the connection and "short out" individual loops on each coil.
This way you can very easily match the coil transceivers without worrying about their length,
inductance or impedance.
Match them to your input by monitoring the receiver on your scope.
then tune the next coil to receive the signal from the first.
Now add your capacitive circuit and feed it back in.
Now you know how it works.
You can use SM's source, or
Choose an impulse of your own.
Maybe an FM channel maybe stellar emissions?
It doesn't have to be the Schumann
This is just one free energy source, and happens to be the one chosen by SM.
And I have to agree with his choice, because its' magnitude exceeds our human needs.
