Creating TPU Steven_Mark
Started by crashangel, September 06, 2019, 02:25:16 AM
Turbo
Quote from: rensseak on September 24, 2019, 11:56:10 AM
Turbo, if you know it so good, where this picture is coming from and what do you know about them?You mean what is mentioned in the pdf file comes all from SM? Who was drawing the arrangement of the coils?
Not where it's coming from but that it is incorrect yes i am sure of that.
Those pictures are the worst ever, they follow the old model and do a very bad job at it.
What is mentioned in the pdf compilation files is the combined communication over email between Steven and Mannix.
These are not made up and it is VERY EASY to show why these coils you posted are wrong so i suggest you start reading.
Because something tell me that you haven't read it thoroughly enough.
I know you was around in the early days and i was surprised to see you dump that garbage into this thread.
I was wondering why did he do that.
rensseak
Quote from: WhatIsIt on September 24, 2019, 06:21:29 AM
"About the collector:
It is three separate coils of  multi strand copper wire laid one on top of the other, not interleaved. "
The collector coils are on top of the other.
If you were observed, would you say it frankly how it is made?
Three is important.
You can do many things  with three coils.  You can run them  in parallel, you  can run two in series and one in parallel, or etc.
Here starts the difficulty too many possibilities.
You can run a separate  frequency into each coil  for  better control on large power units if need be.
Is this mean that only one frequency is used, but separate frequency can be used in each coil?
The control wiring is vertically  wound in several segments around each of the horizontal collector coils.  Other control  wires are wound around all  of  the  horizontal collector coils together.
Here, the collector coils are horizontal?
As I said already above, he did not say it frankly. If you compare it with TPUs in the videos, then how it will be?
First, the 3 collector coils are on top of each other, then collector coils are horizontal?It makes no sense. How this arrangement looks like?
Can you see?
It also indicates only one frequency for all 3 coils? Separate frequencies can be used if needed?
I am little bit confused with this arrangement.
That's it. He had to be careful with what he says.
You know, I've been following it from the start, but then there was a time when members left this forum and went into a new one and not everyone had access there. These members were then allowed to learn something more. I was the one which ask SM if they tried it also south of the equator and it seems he was surprised someone would ask it.
Turbo
Wherever it's coming from it's garbage so that place must also be and now i think of it, i probably know where it's coming from.
Could you do me a favor and make sure it stay's there ?
Thanks.
rensseak
Quote from: Turbo on September 24, 2019, 12:42:46 PM
Thanks.
I will not remove it but for sure is this picture where made in CA.
https://postimg.cc/sBGf5hDC
Turbo
This is both horizontal and on top of each other.
Except for the fact that the first method was confirmed to have incorrect winding relationship.
