Wireless energy transfer experiments ,Builders board
Started by ramset, September 18, 2019, 09:15:01 AM
stivep
This set of writing is not politically motivated
However  it is done in 10th anniversary of the day  when  me and Tariel Kapanadze
- we met  and traveled together from Prague Czechia  to Tbilisi  Georgia Europe.
I have now the two sections dedicated to  English and   Eastern European audience.
-In Russian language section  I will try to  make that what is the most important for experimenters to be also in English.
-Both sections  will share links  so any audience can get to the most interesting material.
-In English section  I will make  additional information related to basic given in Russian section.
_________________________________________________________
Start from here  if you will:
This section  is giving  orderly   information  about what is next there.
https://overunity.com/18913/in-russian-ekspierimienty-po-biesprovodnoi-pieriedachie-enierghii-doska-stroitieliei/msg559508/#msg559508
QuoteFirst to be able to  see if  extraction of energy from Schumann waveguide is possible
we need to  understand  and test the energy  transfer from  given point A to given point B.
TOOLS NEEDED:
This  set of comments  is giving  information about tools needed to tune Tesla Coil into Complex Brewster Angle.
it applies to both :
- energy  send from  any point A to any point B on the  planet Earth
- Extraction of energy from Schumann waveguide  using exactly the same mechanism .
  At the end - this is our FE.
Explanation:Complex Brewster Angle is the angle of tilt of EM Wave  towards Interface  e.g Earth Air
Please note that none of these  devices is mandatory and all is needed is just AC V meter:
-working at best         from 60Hz to 160MHz.
range from Air/Earth ,Au or Cu foil /Air,  dielectric/dielectric or  Goubau line.
-working at medium   from 60Hz to  60MHz.
-working at worse      from 60Hz to  500kHz.
introduction to these devices was given here in link below:
https://overunity.com/18913/in-russian-ekspierimienty-po-biesprovodnoi-pieriedachie-enierghii-doska-stroitieliei/msg559509/#msg559509but more extensive material will be given here
Wesley
stivep
#1. Wandel & Golterman  Selective Level meter SPM-19 50 Hz to 25 MHz
    https://www.sglabs.it/en/product.php?s=wg-spm-19&id=1608
      https://www.youtube.com/watch?v=0NvAtVBE3ZI
      https://www.youtube.com/watch?v=TN6BhmxvkK4
      https://www.youtube.com/watch?v=AkMF_v_vNoE
      https://www.youtube.com/watch?v=fl65xJeeQRQ   Wandel&Goltermann демонстрация работы
#2 HP3586B selective level meter shown as HF receiver 50Hz-32.5MHz
http://mgte.com/slm/index.htm
     https://www.youtube.com/watch?v=_sbxd-Z5jts
     https://www.youtube.com/watch?v=8MZpnVs6CWc
     https://www.youtube.com/watch?v=oeN2bw8iRtk
     https://www.youtube.com/watch?v=TvvBotmw6EQ this is model HP 3586A
#3 Anritsu ML422C 50 Hz to 30 MHz Selective Level Meter Селективный измеритель уровня от 50 Гц до 30 МГц
     https://archive.org/details/lost_manuals_Anritsu--ML422C--user--ID5908/page/n1/mode/2up
     https://www.youtube.com/watch?v=BbnM3ei_eVQ
#4 Микровольтметр селективный В6-1   Диапазон частот: 15 кГц – 35 МГц. 15khz-35MHz
     http://www.cqham.ru/hpa/v6-1.htm
     https://www.youtube.com/watch?v=pDBF9KsXJsE
_________________________________________________________________________
Additional equipment listing   in addition  to that listed  here:
#5  Wandel & Goltermann PSM-139 Selective Level Meter, 50 Hz to 32 MHz
#6  Wandel & Goltermann  SPM-38 WG
      https://www.youtube.com/watch?v=X4_fKnF5pmY   50 Hz - 18 MHz
#6a Wandel und Goldermann SPM 30 Längstwellen empfang VLF Receiver
       https://www.youtube.com/watch?v=lVfx1ggCpyI
#6b Wandel und Goldermann SPM-15
      https://www.youtube.com/watch?v=TEZ1Fhmrp0A
#7  Siemens D2008 Pegelmesser Selective Level Meter
      https://www.youtube.com/watch?v=z0YoPDRxLAQ
#8  Watkins Johnson HF-1000 DSP Receiver
      https://www.qsl.net/n9ewo/wj8711.html     https://www.youtube.com/watch?v=UDVsbFtso5w
      https://www.fenu-radio.ch/Watkins_Johnson_HF1000-en.htm
#8a More about  other  Watkins Johnson receivers is here but  doesn't  apply to our needs.
       http://www.tuberadio.com/spooksets/WJ-catalog-May-1988.pdf
Wesley
stivep
This is special section  dedicated to little different  instruments
that can be also used in our Zenneck Wave device  testing and development
#9  VLF2 Alexandersson 10-300kHz
      VLF2 (grahn-spezialantennen.de)
      https://youtu.be/i2t2AhBggyw?t=46
This module is shown  with association  of selective level meter but it   can  act as stand alone device.
Normally I would never forgive the author - use of  wording <Longitudinal>
but  because it is German made device,  we know that it is not  "Russian joke"
Magnetic field antenna
Very interesting device  and inexpensive.
It has  2 ranges:
1. 10kHz-70kHz
2. 60kHz-300kHz
Wesley
stivep
One  of examples of VLF antenna, that mainly works at 136kHz.
Note  antenna must be  vertically polarized to work with our  application.
This is exactly  the way that is shown in the video but we don't need two loops
The antenna may be mounted  just  on simple portable stick,
The purpose of this antenna  is tune Tx Tesla coil to minimum signal if Far Field.
This will indicate that we are Tuning Tesla coil close to Brewster angle .
the exact mechanism of that tuning  will be explained  in later comments.
https://youtu.be/4WwrKC91A1M?t=325
Wesley
stivep
Very inexpensive  way of receiving VLF ( Very low Frequency  signals) :
-with sound card.
-home made receivers
-receiving VLF Stations With an SDR (software defined radio) receiver
Очень недорогой способ приема сигналов VLF (очень низкочастотные сигналы со звуковой картой) или приема станций VLF
с помощью приемника SDR (программно определяемого радио).
1. https://www.youtube.com/watch?v=L2W1x6Rb9hI&t=99s
2.https://youtu.be/OzWBxt_TOWk?t=620
3.https://www.youtube.com/watch?v=UbbDPqdxq24
4.https://youtu.be/I0luIo78fIg?t=46
5. TitanSDR by ENABLIA    (software defined radio) receiver 9kHz to 32MHz
   https://swling.com/blog/2015/06/a-review-of-the-titansdr-pro-software-defined-receiver/
   designed specifically for military and government applications
   https://www.rtl-sdr.com/a-review-of-the-titansdr-pro/
   https://www.youtube.com/watch?v=VZF7Tp8ymzI
6,Receiver SDR Radio 10K-2GHz Software Defined Radio  only  $49.53
   I don/t trust Chinese products.
   https://www.ebay.com/itm/363495515244?hash=item54a205646c:g:1ukAAOSw7ndhDOJa
Wesley
