"Quantum Receiver".
Started by synchro1, December 06, 2019, 06:08:06 AM
Toolofcortex
So you think stiffler and Hendershot have something in common?
Look at the stacked magnets.
http://www.resonantfractals.org/PCC/Hendershot.html
And look at those nodes, I wonder where Bruces electron ejection theory fits into this.  I'd be ready to bet he is trying to maximize this effect.
https://www.youtube.com/watch?v=pux_QHARA5Y
But the show stopper for Hendershot is just the coil, its too long to wind, versus a TPU that could be machine wound if you were to test many.
What can I do that Libra Spirit didnt do? The guy is top quality. All I got more is that I watched Bruce TPU's electron ejection video, I dont feel confident at all with Hendershot.
Find me those coil designs synchro1. For the TPU.
Some metallic or soft material looped/pulsed, with coils on top also pulsed but perpendicular, so 4 pulses ( Am not sure now anymore). Maybe an initial pulse train is given to this loop then closed and disconnected.
Figure it out I guess, what causes the chain reaction, you are the esoteric wise man, not me.
Play with this idea, Its like the evolution of Stiffler, because first of all his house is a palace, his videos are excellent photoshops at worst, and the power was satisfying.
Vs your tech, with unproven power capabilities, perhaps very meager.
Play with them coil ideas  synchro1.
skywatcher
Quote from: synchro1 on December 10, 2019, 07:37:22 PM
https://www.youtube.com/watch?v=1y3AcIlBSX0&list=PLO6FJVqlxatcX-8A4L7fhyUUlYJcdNziq&index=11&t=0s
At 3:28 in this video, Dr. Stiffler states that his L-3 coil has an SRF (Self Resonating Frequency) of 13.6 Mhz.
But he also says that it would work with other frequencies as well, if everything is tuned to resonance.And 13.6 MHz is not 13.54 MHz.
QuoteThere is no current going from the wire to the loop!
RF needs no direct wire connection to transfer energy. Some years ago when i experimented with HF transmitters and magnetic loop antennas i also saw weird effects sometimes, but everything was explainable in the end. I still don't see anything really remarkable here.
synchro1
Quote from: skywatcher on December 11, 2019, 05:59:54 AM
@skywatcher,
You will catch on eventually. Once again; It's not RF energy, it's power from the Vacuum of Space. There is only a capacitive link, not RF magnet wave. There's no Radio Wave that could carry enough power to illuminate 12 LED's to full brightness!
synchro1
The Universe filled with infinite voltage beyond the boundary of light travel over distance in an instant and never lost any power. Energy can not be destroyed.
A diode loop impedes current flow in one direction. The pressure of the "Lorentz Force" against this dielectric is at 90 degrees. The right hand rule dictates that the 90 degree force turns the energy same way! So as Dr. Stiffler states; Current flows spontaneously through this loop from the difference in potential between the diode layers and the infinite voltage of the Ether.
Now that leaves us asking; How do we get the current out of there? He first gives it a place to go, then provides a way to help it run in.
There's a field of "Infinite Voltage" surrounding the diode loop! This is pure potential. Modulating the static field at 13.52 Mhz (Mayan number) unlocks a "Transmission Keyhole" for the high potential to flow from the vacuum of surrounding Space, to the discharge destinaination inside the LED's.
skywatcher
Quote from: synchro1 on December 11, 2019, 06:45:42 AM
LED brightness is not a precise power measurement, and brightness is often overestimated.
It takes only a few mW to illuminate these LEDs.
