Thanks to ALL for your help!!
Two kinds of induction - Henry
Started by nix85, January 07, 2020, 12:58:05 AM
nix85
This has already been mentioned here but i don't think everything Joseph Henry wrote about it was shared. This is from Scientific writings of Joseph Henry, Section 11, PDF file pages 178. - 185. >> https://i.imgur.com/exKSHHB.jpg
The book >>
https://ia800302.us.archive.org/27/items/scientificwriti03henrgoog/scientificwriti03henrgoog.pdf
Altho some of his experiments are not totally clear due to lack of diagrams or better language, it is made perfectly clear, two distinct kinds of induction are observed, one weaker which cannot be screened except with iron and another that can be screened by any metal.
He concludes suddent breaking of contact produces both kinds of induction and that this mysterious first type is akin to induction produced by motion.
Also closely related to this, not my thought but from a guy in that most famous Eric Dollard conference from late 90's...
Ask yourself how does flux running through the core of a transformer induce voltage in the secondary altho it is totally confined in the core and coil is outside of it.
Question also arises if that 'feeble' unscreenable type of induction becomes not so feeble with higher frequency and suddeness of discharge.
kajunbee
Good question and hopefully someone can answer your question. I've also asked myself the same thing. I believe what I often overlook is the intimate relationship between the magnetic field and the electric field. In your post it says one can only be shielded by iron and the other shielded by other metals. So if you can answer the question whether and electric field can be shielded by materials other than iron then that may be your clue. Sorry that I'm not able to directly answer your question. Smart questions deserve smart answers. Hopefully someone can give one.
nix85
In simple words, it is by etheric disturbance, magnetic field of the primary affecting the higher order of energy which is then picked up at the secondary and transformed back into magnetic field.
nix85
About ether http://villesresearch.com/ether.html
Etheric Rainmaking with Trevor James Constable
https://www.youtube.com/watch?v=MjeUhQJp5WE
To better understand etheric energy you would have to read
COUNCIL OF 7 LIGHTS and WHEN STARS LOOK DOWN
by George Van Tassel.
sm0ky2
Whoever told you can can magnetize a ferrous material and keep 100%
of the flux "inside the material" was pulling your leg.
Even below saturation, the material produces an external field.
If flux occurs through the material, the external field also fluxes.
Take even our best example of semiconductor grade ceramic ferrite
(or their more expensive rare earth cousin)
Operate the device and place a compass outside of the material.
You observe deflection.
How is all of the flux inside?
If it was all inside, there would be no induction, only conduction.
And the inductive core wouldn't stick to a magnet!!!
The electric field induces the magnetic, which in turn induces an electric.
100% of this conversion takes place outside of the ferrous material.
In fact, the core doesn't even need to physically exist.
This won't change the mode of operation. Only the variables.
