Real Free Energy from magnets !
Started by r2fpl, March 09, 2020, 09:21:54 AM
lltfdaniel1
This simple compass effect where it can't stop spinning will keep on accelerating and accelerate tapping into the magnetic flywheel which is what causes it and yes excess power to power a load.
You can do this without the earth since view the earth as a simple magnet and try to work out why it spins to no end and in the process it will get faster and faster in rotational speed and yes there is work in the acceleration meaning it will power a load whilst self sustaining with it's acceleration spin effect here.
This is key as to how to get permanent magnet motors to work because of the magnetic gate and this effect is what every inventor can dream off as to how to get a magnetic motor working fully.
So instead of the earth magnet flywheel you can tap into an actual magnets own magnetic flywheel.
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
r2fpl
Quote from: lltfdaniel1 on March 09, 2020, 02:40:42 PM
Maybe it's possible. My tests prove that it is FE. Is this enough? it looks very little but it is.
It is interesting that the neodymium magnet did not spin faster. Magnet power is not associated with this phenomenon. I think so.
The differences in rotational speed are more for the mass of the magnet than for its magnetic field.
conradelektro
Quote from: r2fpl on March 09, 2020, 01:04:47 PM
I don't make fake movies!
...The string is "woven" in a special way.  ! NO SPECIAL ! normal !
please check it yourself if you don't believe it. It's very easy. You will be surprised, guarantees. If you can put a movie.
Instead of me making a movie with a string, you could make a movie with an axle.
I do not claim your movie is fake, I only claim that the string and the weight of the bar are the cause of the spinning. It is hard to define what a "normal" string is. Use a polyamide fishing line. Stick a little rod through a ball bearing and suspend the fishing line from the little rod (so that the fishing line can spin freely).
Ok, I am not prepared to do experiments along your line of thinking, so I shut up and let you win whatever argument you want to win. You can become rich and famous and I will not stand in your way. A genius should not be hampered. The world is entitled to profit from your discovery.
Greetings, Conrad
lltfdaniel1
Quote from: r2fpl on March 09, 2020, 02:47:38 PM
Yes whatever way you see it, it is free energy the interaction of your magnet colliding with the moving rotational flywheel which causes the earth to spin, will cause your magnet to spin, think about that.
There is real power in the earths flywheel and your magnet spinning also has that real power , which means you can get usable excess energy because of that.
What i am saying is, there is real torque and power with the earths rotational fly wheel, and when you connect your magnet with it, the potential goes into your magnet, meaning your magnet can self sustain with rotational moving as well as powering a generator with a load and fully work that way.
Forget about frictional losses, the power of the momentum both overcomes it regarding fiction loss and self sustains with excess power to power a light bulb.
Like a fly wheel of a car engine, and a inter link flywheel see it that way.
Your tapping into the earths flywheel of motion so as the earth moves there is momentum and when your magnet communicates with it, in a compass like way where it won't stop spinning is how that is done.
conradelektro
Exactly what I am claiming, the weight of the magnet bar (or ring magnet) together with the string (its properties) cause the spinning (till the string reaches the limit of its stretchability).
Use a fishing line (technically speaking: a monofilar string)!
Greetings, Conrad
