Thanks to ALL for your help!!
Alternative Partnered Output Coils and Free Energy
Started by Raycathode, April 03, 2020, 12:14:05 PM
Raycathode
Quote from: nelsonrochaa on April 04, 2020, 11:09:07 AM
Hi Ray, are you talking about exactly circuit ?  Could you point me please to the link of topic ? Thanks ;)
Best Rewards
Nelson Rocha
Hello Nelson I'm getting a bit confused here sorry, which link are you referring too A. your circuit to T1000 in the Dally thread  back in last May?
or B. Mr video of the bucking circuit / field ?
If your talking about your circuit I have just found it but after all the time laps I think I might have made a mistake as your layout
Looks rather like the circuit you published using series parallel inductances, however you appear to have miniaturised the circuit and
Produced the same effect using off the shelf inductors if I'm not mistaken.
I don't suppose you could comment on the subject
Sorry about that but I'm still learning slowly.
Regards Raymondo
PS if you want me to deleate any of this let me know !
nelsonrochaa
Quote from: Raycathode on April 04, 2020, 11:49:34 AM
Regards Raymondo
PS if you want me to delete any of this let me know !
Hi Raymondo ,
I really don't remember post that circuit in OU ! .
I think i only share a video about that with AlienGrey but never share any diagram to duplicate them.
But I am not shocked :) that my things have been appearing around since they pirated my personal data in my pc; the deleted almost my accounts, and stolen private information ... is really sad but is the reality .
Yes that circuit is a small simplified model to study some aspects similar with the related theme of partnered coils , but i never finished that circuit ,but i have that circuit :) maybe i could remove the dust and try put it work again ;) .  If i remember , that circuit run in auto-resonance without use any external signal .
What is your doubts about that circuit ?
Best rewards
Nelson Rocha
Raycathode
Quote from: nelsonrochaa on April 04, 2020, 12:15:31 PM
Hi Raymondo ,
Best rewards
Nelson Rocha
Hi Nelson you can find the posting here on this page https://overunity.com/12736/kapanadze-cousin-dally-free-energy/21240/
So is the circuit self oscillating only 2 or 3 wires toddle off unseen some where, you must perhaps use some sort of vfo with feed back locking
I would have thought and the other problem is the output isolation use of the mains filter and choke. Which is a little mind boggling
with out seeing how your advanced mind knowledge has sorted that one out  8) as i said I'm unprofessional but like experimenting on a
Educational level.
Regards Raymondo
WhatIsIt
Quote from: nelsonrochaa on April 04, 2020, 10:58:53 AM
But to me the most important point is how to "blind" the input ; this means ; make use of the output without increase the main input current, if that is not achieved, well ..
How did you blind input?
How much AC source spend if it has only one capacitor in circuit? (or one inductor?)
Basic knowledge.
Source does not see capacitor, zero consumption.
Let's say that bucking field coil has only 0,1 ohm resistance, zero inductance, high gauge copper.
If we connect serial with that capacitor zero inductance bucking field coil of 0,1 ohm,
will the consumption of source change a lot or near nothing?
Can you extract energy from bucking fields while source consumes nothing?
Source is blind in that case.
Now, we are coming to essence of my current research.
How different arrangement of bucking electrical field only,
bucking magnetic field and both bucking fields together combined gives different solutions to that situation.
For example, bifilar bucking field coil has strong electrical field because the way it is wound.
(Floyd Sweet, kill magnetic field, double electrical field).
What will happen?
Just one example.
Quote from: WhatIsIt on April 05, 2020, 10:29:25 AM
Basic knowledge.
What will happen?
Just one example.
"Source is blind in that case " in german for "reactive current" in use "Blindstrom" 8)
                                              https://www.youtube.com/watch?v=ekeptjvd1zE
                                           hot,hotter or near,nearer + nelsonrocha ; dielectric  ;)
                                               reactive current to active current conversion
                     net-grid negative power to positive power without extra-costs "Blindstrom-Kompensation"
                                              Maxwell "displacement current"
