New Topics 2020 : Moving forward as a community
Started by ramset, April 22, 2020, 09:56:52 AM
h20power
Hopefully I'll be getting back to work on the water for fuel technology soon as I had quite a few things chew up my time in that past several months. My father passed away a few years back and my sister gave me his old car which it just so seems to on it's way out just as it was given to me. First off it wouldn't hold a charge so I looked into it and someone put that wrong size and type of battery in the car $218 bucks later that problem was solved. Then the suspension gave out so I got some new shocks and springs and some $400 bucks later that problem was fixed. Then the car had a over heating problem $40 bucks later that was fixed. Since the car seemed to be run hot for quite a few years all the plastic parts are very brittle and while replacing the electric thermostat I broke the ignition coil $70 bucks later that was fixed. I figured I might as well replace the spark plugs and $20 bucks later that was done. Then the car starts a really annoying misfire so I got some new plug wires figuring that would solve the problem, not that set me back $70 bucks. And the transmission started acting up which has thus far set me back over $140 bucks. Now the car has fuel system problems and who knows how much this is going to cost me to get fixed. It seems the car was dying when it was given to me as all of this happened within 2000 miles of the car being given to me.
Hopefully next month I'll get it all fixed up and once again be free to work on this technology. The plan was to fix this car up and give it to my oldest daughter so she could have a car while going to college that was dependable. It's a good thing I'm a mechanic or those repairs would have cost me more than likely well over $3000 to have fixed at the mechanics shop. In the mean time I keep a watchful eye out for anything dealing with this technology and thus far it would seem I am practically alone now working on this technology with just two friends hanging in there with me.
I'd thought after sharing the actual science behind this technology someone else would, whom didn't run into all these problems, would have a unit up and running by now, but it seems all of the blocking that took place after I posted the information did it's job as it seems no one even attempted to use the information I posted. It's okay, as I know this technology isn't for the faint of heart as it is on the complicated side to get working correctly. Dealing with ionization energies, standing waves, and a whole lot more isn't easy but it is the way forwards if the world is to have a replacement for it's fossil fuel addiction that will actually do the job and a whole lot more.
As for what it takes to be a moderator I know I have what it takes because I know how to call someone out for being a knuckle head, deal with them, and move on. All of that blocking simply wouldn't have been allowed after I posted the science behind this water for fuel technology if I was the moderator so that people could ask questions if they didn't understand the science I showed instead of having a bunch of garbage data post after post to bury the technology as was done. The way I see it it's this sites loss as I was willing to answer questions at the time but now not so much. Now I just figure someone has to attempt to bring this technology out and I am all I see actually making progress on this technology thus I have to be the change I want to see in this world as someone else might get it wrong.
onepower
H2Opower
QuoteI'd thought after sharing the actual science behind this technology someone else would, whom didn't run into all these problems, would have a unit up and running by now, but it seems all of the blocking that took place after I posted the information did it's job as it seems no one even attempted to use the information I posted. It's okay, as I know this technology isn't for the faint of heart as it is on the complicated side to get working correctly. Dealing with ionization energies, standing waves, and a whole lot more isn't easy but it is the way forwards if the world is to have a replacement for it's fossil fuel addiction that will actually do the job and a whole lot more.
That's an excellent build in the picture.
It's easy to spot the people who know what there doing and can actually read. Meyer's basically spelled out most of his technology in his various patents however few know how to follow directions. I can see you have put in the time and effort to do this right, well done.
Initially I also lathed my coil former's out of poly then switched to 3D printing with PLA using acetone to smooth out the finish. I also found at higher voltage/frequency poly and more so ABS/PVC produce excessive leakage. This can be fixed by coating the coil former's with epoxy or varathane before and after winding. You may have noticed power and wave form instability because of leakage which is due to relative humidity. It took me a while to find the problem and I couldn't figure out why some days my circuits worked fine and other days nothing worked. It was relative humidity, water vapor in the air acting as a large variable capacitance also conducting energy away from the circuit. It can be something that simple which determines whether our results are as expected or not.
QuoteHopefully next month I'll get it all fixed up and once again be free to work on this technology. The plan was to fix this car up and give it to my oldest daughter so she could have a car while going to college that was dependable. It's a good thing I'm a mechanic or those repairs would have cost me more than likely well over $3000 to have fixed at the mechanics shop. In the mean time I keep a watchful eye out for anything dealing with this technology and thus far it would seem I am practically alone now working on this technology with just two friends hanging in there with me.
I have a similar problem with my 1947 9N tractor which managed to drop both the rear engine seal and the transmission seal simultaneously this summer. Now I have to spit the damn tractor in half just to change a couple seals and the clutch disk, not cool. That old girl just keeps chugging along even after 73 years but she's high maintenance. I'm not a mechanic but grew up on the farm and have never taken anything I own to a mechanic to get fixed, no offense. As you may know sometimes it's just easier to do things ourselves so we know what were getting and it's fun... sometimes.
Your not alone with this technology but I know the feeling. 99% of people don't know about FE technology or care to know for some reason. I started with vapor carbs and water injection when I was 18 damn near 40 years ago. Got into designing and building micro gas turbines in the 90's then moved onto some more exotic stuff like Victor Shaubergers work and hydrodynamics. Later I discovered Tesla, Sweet, Hendershot and the boys once the internet became more popular. So for some of us FE technology is not all that new simply a continuation of our learning curve.
I think it's important to love what we do and want to learn more beyond anything else. To disregard all the nonsense we see happening all around us if we can and move ourselves forward.
QuoteNow I just figure someone has to attempt to bring this technology out and I am all I see actually making progress on this technology thus I have to be the change I want to see in this world as someone else might get it wrong.
All of the greatest inventors and scientists throughout our history acted alone. Sure many wanted to take some or all of the credit after the fact however they acted alone because it was there dream they were following not others. I say go for it but be careful, plot your course , be methodical, have a backup plan and don't sweat the small stuff. As well over the years I have learned when most people say they want to help they mean help themselves in some way so caution is advised with respect to human nature.
h20power
Thanks Onepower, Here is the proper way to build high voltage transformers as the air is the enemy, something I found out the hard way. I tried transformer oil at first but it's not good enough for this technology so I use a high voltage epoxy and cure it in the oven after using a high vacuum to get all the air out of the transformer: https://www.youtube.com/watch?v=i0gH4IX5r7g
This solved the problem and now I can reach voltages well over 10kv without the transformer arcing out on me internally.
Here is Don Gable experiencing this internal arcing: [size=78%]https://www.youtube.com/watch?v=AQeZ9EgpgXw[/size]
When mines arced out it went up in flames as I was applying a lot more power to the primary coil getting around 9.2kv to the cell. For my cell I have to get over 10kv for it to work correctly as I have ten resonant cavities wired in series. Now I do apply gating to get the stepping voltage in my waveforms unlike Don is doing and my waveforms looks a lot different as a result but it is putting out both positive and negative voltages just as Don talks about. It must do this to mimic a thunderstorm as that's how the earth's global electric circuit works to break the bonds of many different types of molecules water being one of them, but it also breaks down Nitrogen molecules, Oxygen molecules, Carbon Dioxide molecules, Methane Molecules, and in fact any molecules that happens to be present when the conditions are right will be broken down by a thunderstorm. It's the earth's natural air cleaner but our use of fossil fuels has overwhelmed the system thus all the trouble we are in right now with climate change.
I wish they would teach this in our schools and colleges but I guess those that sell energy don't want this being taught in our educational systems so they can keep making a profit. Anyway I figured it all out making use of the scientific method asking and answering questions the old fashion way. And be assured I do have a plan that I am following🤫[/font][/size][size=78%].[/size]
[size=78%]
[/size]
[size=78%]Take care,[/size]
[size=78%]Edward[/size]
