Nelson Rocha Workbench
Started by hartiberlin, April 30, 2020, 02:57:05 PM
EMJunkie
Hey Nelson,
It appears active research is extremely slow to non existent here. Sadly...
My thread is the same! The brilliant young minds are all focused on off topic nonsense. Very few real builders remain. Even fewer serious researchers are here focusing on the topic at hand.
Yesterday we had another excellent result on my forum, the most simple device, putting out more than 4 times more Energy that was input. As you know, when we get to this and further stages, we cant help but look at those not giving this a serious effort as Time Wasters.
My Friend, we have known each other for more than ten years, I don't want to post to your thread information that is Negative!
So, I ask all readers: Get serious! Get your Brains switched on! Focus, Learn! Nelson will eventually get sick of sharing if you don't put the effort in! He can not be here forever!
My Friend, I wish you well, be safe and stay well, don't give up, there is a bright future ahead, many will not make it unless they pull Finger!
   Chris Sykes
onepower
Nelson
QuoteYou are not the first person to tell me that they had difficulty with replications of some circuits I share . But a large majority did not even manage to reproduce them, even before starting it,if you know what I mean.
Each person has his own state of mind and perception.
As you may know the unfortunate truth is that doing anything in reality is difficult. It's just hard work which seldom works out as planned and requires a great deal of time. Most people cannot even comprehend the work you put into the devices I have seen in many of your video's. I think we may be a special breed of crazy for tormenting ourselves like this.
QuoteAbout you circuits working with no gate or limited  gate/base connection:
The darlington transistor have a high gain , and they can work with "external" signal provided byelectric field, like mosfet gate could work just with a parasitic capacitance , myself already made some circuits in the past with those similarities , so when someone tell you that could not work , first explain to person why that happen's , and  after that if he continue say that could not work, just smile and move away, most of times is better :) . but well I understand you type of "gate driver" .
In what type of application you apply this technical point ?
In the past I use this  technic to some high frequencies detectors  ;) because are able to detect "spontaneous frequencies" .
My work is similar to yours in many respects however most of my circuits run anywhere from 10 to 500 kV which as you can imagine presents many problems. This kind of potential basically obliterates all off the shelf electronics so most components and circuits based on LV conduction becomes problematic. As such my normal is based on field effects and detection at a distance not so much conduction. I usually have to purpose build almost everything from scratch simply because nobody makes the specialized HV components I require. I enjoy it because it's unique and I can seldom predict what is going to happen which is strange and exciting.
QuoteHope you could present us with your work in future, will be well received by the community.
I had thought about it many times over the years and I have shared some things in the past however it becomes problematic and seldom ends well. I think I may be selfish and I research and experiment to learn and understand nature. That and I want a FE generator in my utility room and a UFO parked on my lawn, I'm not asking much, lol.
Dog-One
Quote from: nelsonrochaa on May 14, 2020, 04:38:29 PM
Feel free to present your thoughts and ideas. Welcome !
I most certainly do have some thoughts and it's really good to hear from you again.
Years ago when I first started looking at your pancake coil work, I had fabricated some really nice PCB flat coils.  I made clockwise and counter-clockwise traces that could be perfectly aligned so the traces would lay exactly on top of each other.  I could then use various dielectric material between the boards to change the properties of the complete coil.  I located mounting holes so the plates could be tightly fastened together.
I did a lot of experimenting with these coils and because they were so precisely made, the results were very repeatable.  This leads me to the question...   Do you have in mind some basic experiments we should  attempt, with the vision in mind of where we all should end up as we begin to comprehend the inner most details of this exploration?
Oh, one other thing I should mention:  Switching...
There is a company that produces Silicon Carbide JFETs.  They absolutely put anything I've used prior to shame.  Being normally conductive JFETs, they flow current bidirectionally with practically zero resistance and they are extremely fast when driven with the proper gate control circuit.  I used them successfully with many parametric resonance experiments--the waveforms show almost no artifacts of the switching taking place.
nelsonrochaa
Quote from: EMJunkie on May 21, 2020, 05:27:40 PM
Hey Nelson,
   Chris Sykes
Hi Chris ,
I am very happy and grateful for your sharing Chris.
I will try to take a look at this replication that you speak and maybe if i could try replicate them, because 4 times more Energy that was input is really a very good result!
What kind of measurements were made to reach this admirable value? What type of load used ? Resistive or inductive loads were used in the (output) to verify this gain ?
My time is a little reduced in this moment , however, I hope in the coming weeks to start to dynamize the thread a little more, because I need to organize myself in relation to some themes that are essential to i able to materialize some ideas to something replicable by everyone .
At this moment I am also trying to gather equipment that will allow me to start.
But everything has its time, and I hope that soon there will be good changes.
Best rewards
Nelson Rocha
nelsonrochaa
Quote from: onepower on May 22, 2020, 12:06:43 AM
Nelson
Hi Onepower,
Yes, you are absolutely right, this activity can take a long time to materialize in positive results.
Above all, it is a route we choose voluntarily, and those who run for pleasure never tire!
I'm impressed with the type of system you're working on.
I myself am passionate about high voltage due to the unknown aspect and the events created by it.
10 to 500kv is a really high voltage , if not properly planned, it can lead to serious health problems, as chemical, ionic and transmutation events occur during this type of high voltage experiment, but it shouldn't be new for you if you work exclusively with these voltage levels; stay safe .
I understand that you may have had bad experiences in the past when you tried to share some of your ideas, but I believe that there are conditions right now so that you can present your ideas without restrictions. I could personally support you in this task, in case you need any help.
Best rewards
Nelson Rocha
