Kundel Torque Amplifier
Started by synchro1, July 15, 2020, 02:50:24 AM
Reply # 59 "fan"
compared
Dr.Giles Pearson DE3211338 Wind-force power generator
Natrium-/sodium coil as rotor !
synchro1,I think you will now enter into te pyro-/piezo ceramic technology stage !  ::)
The stator, making part from an earth motor ?US2003222512 Hanna Awad
synchro1
these half circle magnets would help;
synchro1
two connected reversed polarity diametric arcs would act as a propulsion housing for a split disc piston.
synchro1
Masking the Disk magnet with a coil charge, then positioning it at the peak of the torque gate would cause it to fire like a projectile when the power was disconnected. Pulse recovery would neutralize Lenz drag.
Overunity is apparent when we measure the extra torque of a second ring against the equal masking force for gate entry of one.
synchro1
Pushing the spline erect split disk through a diametric tube that is free to rotate inside a collar bearing will cause the tube to rotate; Holding the tube will cause the rigid disk to slide in one direction.
Pushing the spline erect disk toward the end and cogging and decoging the tube would shuttle the disk back and forth continuously.
