Kundel Torque Amplifier
Started by synchro1, July 15, 2020, 02:50:24 AM
synchro1
I have orders in for the bearings, the rest I can pick up in town at the hardware store. 2 1" cube neo's and a 1/2" diametric Neo piston should generate the dynes needed to rotate the Kundel gear a half turn with merely 1/2" of throw. This is the first test I am preparing to run.
synchro1
The kundel gear can be tightened in parallel with bushings on the rotor magnet. Positioned right on the kick hump, the diametric piston only needs to move a millimeter, in either direction, to trigger a strong rotation event. This is how Kundel toleranced his patented generator. Kundel claims his generator to be close to 1700 times overunity. It's easy to see why if you read his patent and examine his generator; A very low input rapid vibration results in very high inertial RPM's. Even without the latch mechanisms and springs, with sufficiently powerful Kundel magnets and a good start up shove, this design may begin to  tear itself apart from over acceleration!
No one has seen or been sold so many as one Kundel generator. Can anyone try and explain this? Perhaps Kundel is a victim of acquisition suppression.
synchro1
kundel's final upgrade substituted arc magnets like below for the rectangles.
synchro1
here's how it should look; these are ceramics.
synchro1
One side of the N-S Neo arcs and diametric tube; The neo magnets reduce the piston throw to a hair width; I believe John Bedini's "Ferris wheel" shuttled an output coil core magnet to generate the excess power he used to self run his motor; If so. this design should self run mechanically with the same efficiency.
