Grounding question
Started by nix85, August 31, 2020, 02:43:10 PM
nix85
i been watching rimstar's video on grounding/earthing
https://www.youtube.com/watch?v=zLW_7TPf310
as you know, ground wire is there so in case insulation on phase/live gets damaged and it touches the casing, electricity doesn't flow through you to the ground by through the ground wire which is connected to the neutral in the breaker panel.
what i don't understand, why not connect the neutral to the casing directly and lose the 3rd terminal.
what would be the difference. casing would still be at 0V and in case phase touches the casing current will flow to the neutral and not through you.
can anyone answer this
fritznien
 the difference? Suppose the neutral opens then what?the case rises to the hot and you get zapped good.
nix85
"Suppose the neutral opens" what you mean
i said why not connect casing directly to neutral, instead of connecting it to "ground" which connects to neutral in breaker box
Paul-R
Quote from: fritznien on August 31, 2020, 02:51:43 PM
Isn't that the story of Keith Relf?
Sometimes, there is a leak which goes round and round, causing
mains hum. If you cut the earth, it breaks the circle and the hum
goes away - but there is still a leak - and once the mike stand ended
up at mains voltage. I may be mixing up a couple of cases but Fritznien
is right. Don't do it.(p.s. please post smaller images, 800 max. it messes up the thread).
nix85
still no answer why not connect the casing directly to neutral
