AC voltage from single magnetic pole
Started by nix85, October 04, 2020, 10:16:36 PM
nix85
You mixed the turns, voltage coil should have little turns, not vice versa.
Also you moved magnet by hand altho inductive reactance is undetectable at such low frequency.
It's funny how you try to prove he's right with resistive coils while doing the test wrongly forgetting he is making a claim for PURELY INDUCTIVE COIL.
ramset
NX85
Your use of word "Friends "
Is silly
Implying nonsense
Better to stick to Brutal honesty
There are no "Friends " when it comes
To truth
Just prove the point on your bench
Or accept a bench you will aprove for test !
And set criteria
You are fortunate to be amongst brutal honesty
Not "friends "
Regardless the outcome
The truth matters
And will rule the day !!
Thanks Grandma
nix85
Quote from: ramset on October 09, 2020, 12:47:06 PM
NX85
Is silly
Implying nonsense
To truth
Or accept a bench you will except for test
And set criteria
Not "friends "
The truth matters
It's not silly, there is a clear desire here to prove him right, call it friends or whatever.
Only truth matters, that i agree.
Just don't forget his claim is for pure inductive coil.
Here is one bench test showing clear 90° IV phase shift with aircores.
From description
"In this configuration the little flat coil with negligible inductance read only voltage and detect the position of magnets, the other coils are closed in loop and read the current across one shunt resistor of 10 Ohm. "
https://www.youtube.com/watch?v=m6AOTQlHhTU&;
verpies
Quote from: nix85 on October 09, 2020, 10:24:52 AM
That is relative thing since all physical laws can be skewed or bypassed in certain ways but within certain limits they hold true, see below for an example.
I am all for designing a good experiment that will not skew or obscure the phenomenon being studied.
Your belief.
You are right to call it a belief or a hypothesis or a conjecture until I proove or disproove it according to the scientific method e.g. with falisifibility and replicatibility.
Ohm's law has it's exceptions, incandescent bulb totally ignores Ohm's law, as filament gets hotter it's resistance increases and Ohm's law is out of window,
Not really, it is just a badly designed experiment, namely two disparate measurements of the filament in two very different physical conditions.
If the resistance measurement of a hot filament is made then the Ohm's Law holds.
Show me a near purely inductive circuit in which current does not lag voltage as magnet passes across the coil and i'll be happy to admit this law is bypassed in such case.
OK, but as you have just illustrated, a badly designed experiment will yield bad results, so we will have to design a good experiment to which we both agree.
PS. since you will using resistive coil to prove something about ideal coils, use as thick wire as possible and at least 50 turns.
I could use a NbTi coil but the dewar will obscure its view and the LH is is expensive and will break the clamp-on current probe for oscilloscope.
To do it right you should use two coils, one for voltage and another for current, measure current with a clamp probe for oscilloscope.
That is doable with two identical low-resistance coils and two identical magnets, but the coil for measuring induced voltage should not be in close proximity to the shorted coil used for measuring current because the latter may distort the permanent magnet's flux which reaches inside the former coil.
IMO it is important, that the two coils and magnets are identical to prevent any differences in their behavior. This should be verifiable by swapping their roles at any time.
Also, I think that when both coils are opened and used for induced voltage measurement, then both voltage waveforms generated by them, should be identical and appear in-phase on the scope. Two out-of-phase induced voltage waveforms would indicate misalignment and would necessitate calibration of the apparatus.
Do you think that a result of such experiment would constitute an objective proof or disproof of the 1 BTC challange ?
ramset
NX85 (sorry I posted while Verpies was commenting)Well actually
I beg to differ
It seems your impression is not accurate
I have heard from both sides
And it seems a very good discussion to have
Please do not think any here would be disengenuos
Or dishonest to support an associate (we who hunt FE are all associates)
Science has no friends and should have no agenda other than the truth
Please move forward
Is the post #45 here the issue of contention?
Respectfully
Chet
Thanks Grandma
