Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
giantkiller
Quote from: turbo on May 09, 2007, 03:34:45 PM
Quote from: Grumpy on May 09, 2007, 03:25:42 PM
If you are the original Turbo, then you know how it works:
http://www.overunity.com/index.php/topic,1761.msg18738.html#msg18738
yes, i do know how that works...
because i build that..
but that coil does not work when i pick it up and walk around the house or outside...
we did already go thrue that.
i am looking for the real reaction, no primary to secondary flux, like steven said it.
any thoughts on the cold electricity bug?
Turbo.
Like putting the electronics in the middle? I agree.
--giantkiller.
Grumpy
In case anyone missed the previous post of this book.
Mention of Leyden Jar and Ruhmkorff coils producing RE effect on page 19 is interesting.  The rate of change is key.
http://www.allabouttesla.com/more_about_tesla/inventions/documents/07_02_13_pdf_free_energy_tesla_patents.pdf
        -Frank Edwards
Grumpy
So, the torsion field (RE field) can work with the electric field without the magnetic field to produce work.
QuoteFrom page 25 of "The Free Energy Secrets of Cold Electricity":
Closely examining the white flames,
Tesla realized why there was no measurable
"electrical current" at the crown of these
activated coils. The normal heavy charge
carriers, electrons, could not travel as quickly
as the radiant pulse itself. Choked in the
metallic lattice of the coil, electrons became
immobile. No electron current moved
through the coil at all. The radiant pulse,
which moved over the coil surface, was
therefore not electronic in nature.
        -Frank Edwards
Mannix
Quote from: turbo on May 09, 2007, 02:05:39 PM
pherhaps you can make any wire match to the desired harmonic by making sure the tap point is at the right place..
you can even use a tap point as an end of the wire while it is actually longer..
this will be my next direction of experiments this weekend.
Turbo.
Aye!
But to do this you would neeed something that was fantastically fast...not something slow like molases...Imagine how usless circuit feedback would be here...coil feedback is another matter..I think that  research into something capable of using one kick to trigger the next series ...at the right tap point..
Good stuff Turbo
Lindsay Mannix
I think that between Otto, Yourself  and Roberto..
FatBird
Is it Possible that SM used this Outer Wrap as a DELAY LINE or a MODULATOR to SMASH Frequencies together.
ChemTrails, ChemTrails, What's in your sky?
Google it.
