Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
mrl
Quote from: giantkiller on January 23, 2007, 08:57:39 PM
Quote from: mrl on January 23, 2007, 08:37:37 PM
Quote from: giantkiller on January 23, 2007, 08:33:39 PM
Way ahead of ya there bud! They were free too! Fets and drivers! ;D
Next I get bridge and 3055s.
--giantkiller. 8)
What are you using the 3055s for, if you don't mind my asking?
That is the power transistor 2n3055. I will have back up parts for other test. I snag samples whenever I can.
And I got that schem too.
Do you think that Bedini would blow smoke after all he's been up to at this point to falsify?
He has done too much. About the solid state ckt. Is a coil not needed? Fatbird said the inverer to the coil. So there are 2 trains of thought. I got options. Because with an inverter to the opto and radiant on the other side then this ain't tough at all. But that sounds like alot of shortcuts. ???
--giantkiller.
I'm not sure what you're referring to. Can you elaborate?  What is it that you want to do?
mrl
--giantkiller. 8)
--giantkiller.
Here's another configuration to choose from.  I'm just emitting brain farts here.  You will have to play with the resistor values to get the bias right.
If you're going to experiment with these circuits I would get the oscillator working and not worry about the the SCR circuit (unless one is dependent on the other).
See attached.
giantkiller
Quote from: mrl on January 23, 2007, 09:17:14 PM
--giantkiller. 8)
--giantkiller.
See attached.
I have this schematic too.
If I rejumper my GK4 I will have the oscillator to the coil. I see on the RC3 you added the diode at the base. I'll be at this tomorrow night.
--giantkiller.
aether22
Hey, don't build John Bedini's motor.
I have figured out why that type of motor works.
It has to do with the gap, as the aetheric capacity changes (which can by changed in a C core coil by passing a capacitor (Otis T Carr, Swiss ML and others), a diamagnetic material (Don Smith), or a magnet through the core, this causes a flow of aether to take place in the winding, however no current need flow, first I believe it's possible to wind a bifilar coil (basically a tight canceling multilayer caduceus) to stop magnetic emf induction,or a normal coil can be used and the voltage generated can be opposed by an equal EMF such a battery or rectified smooth transformer.
This makes lots of sense based on things Robert Adams said in a lecture I attended. (about having 2 emf's cancel, that's when you get the effect without current)
It also explains why Peter Lindeman said on working with John Bedini that he could get it to work more as a transformer, or more as a generator, but it worked best when neither action was taking place.
Well that's because if the to a equal they mostly cancel out, it's not the electrical flow we are really after, that is sure to slow things down.
We want the aether to move.
So with the knowledge above you can do better than the bedini motor.
Or just use an alternator!
rectify it and smooth it and if you want cancel the voltage as described.
BTW I am only here rediscovering something that has already been written about in a book called the Earth Energy by John Bigelow, in that book the same info about gaps and canceling windings were given.
As for the TPU here is my pick:
One collector coil is the output, it runs through a static magnetic field. (the static field may have a rectification effect as Hans Coler claimed making it DC)
One collector coil is connected to the feedback coil, for er feedback, if the feedback coil is so important as SM says it must be connected to an output (collector) to feed back)
One collector coil is an open circuit and freely resonates (much like a multi wave oscillator ring) this is the one the input it tuned to. (he says that it was tuned to the circumference of the collector coil, well that ONLY makes sense if at least one of then is an open circuit)
The control coils besides creating the spikes would be good to have a rotational effect and have an electric field between the collector and control coils.
This would then put it in line with Hamel the the Joe Cell and many many others as many devices have shown the aether loves to move at 90 degrees to an electric field.
There should be a wooden core as Steve Marks uses, and GK is probably right about iron.
Please use your heads:
1: Steve said vacuum tubes, not because they have great switching properties but because they have an aetheric output as has often been shown. (RE output if you prefer, or cold electricity)
2: There is a precessional force that can ONLY be created by aether moving as there is no mass moving.
3: He said the collector coil length is tuned to the device or visa versa, it is it's circumference that determines the frequency, this can ONLY happen if one of the collectors is an open circuit.
4: Why do you think he called it a feedback coil, obviously you feed the output back into it, this also helps the aether vortex.
5: Steven Marks went to the bother of using a wood frame, obviously it can work without wood as first time he used bailing wire, but wood is obviously a good idea.
6: Steel collectors ARE indicated by GK's results and SM's statments
7: The collector coils energized in a rotational manner makes lots of sense! both from an aether rotating point of view and others. (kicks adding up)
Thedane
I belive that the TPU is very similar to Alfred M. Hubbard: Coil Generator
He uses a coil configuration which apparently seems much like the TPU.
He also uses 3 different frequencies, one being very close to 6kHz.
The coil diameters are also calculated  :)
http://web.archive.org/web/20060405155758/www.rexresearch.com/hubbard/hubbard.htm
http://www.whackster.com/energy/hubbard.htm
http://web.archive.org/web/20041229201633/keelynet.com/interact/archive/00000259.htm
