Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
TheNOP
Quote from: bolt on September 16, 2007, 07:12:58 PM
I don't know if there are any 3 collector rings. I haven't seen any evidence of that yet.
In the one that got cutted, i can clearly see 3 on top.
For the buttom, i can say i am 100% sure, but i guess there are 3 too.
Colors differences for both area look about the same size.
innovation_station
there are clearly 2 diffrent modles this is the big modle or the 15/17 models they will be easyer to understand than the smaller ones on the smaller ones our balumes are top and bottom as i currently think yes 3 collectors but 2 are for self powering propouses the center one is for out put
in this model when we strike the right cord inside our controls they produce high speed ripples that push aginst mother nature and when she pushes back we trap it and recycle some of it back through the ring this is how i see it
i found a 4 ohm 2 w sterio amp inside a set of computer speekers i will try to use it to send my 3 freqs into my balium  i wound it 50 turns input and 50turns output  and almost finished my 4" unit but it is too small i can only get 50 turn controls i used 22 ga it was all i could find
a pic l8r when i finish it
ist
TheNOP
Quote from: innovation_station on September 16, 2007, 10:41:40 PM
there are clearly 2 diffrent modles...
I would not be so sure about this.
how thick would be 3 turns of a single lead of lamp wire when the insulation is replace with electrical tape ?
giantkiller
I posted the video to show the phase matching that happens at resonant distances.This can happen in audio or any other frequency levels. We know that. Sound, liquids, materials, magnetic, gravity, light. You name it. Thump steel and it crumbles. Use sound to resonate glass and it shatters. So I could then switch my output device from an acoustic transmitter to a magnetic transmitter. Digitally, I REPEAT, digitally control the wave output. At least with Audio I can hear the output and know the transmission speed. With the magnetic transmission I don't know squat. And I'm sitting in the field? I don't light up my life any more. So I thought I would experiment with the audio first to debug the operation. Thank you, Bolt. A refreshing stroke of genius. I could have used a radio too. Thank you, Mannix. But the amazing thing is to be in the field and move the microphone in and out from the center. I did not get hurt. Try that with magnetics!
So today I achieved the steps that were outlined by Bolt. And not only that but a far better understanding of the rogue waves. And it only took a week. I consider that pretty good stats for being the only one on the planet doing this. RFC.
So now I have a very good handle on wave production. I could simply take a microphone patched to a protoboard and see on the scope what amplitude shows up at what distances. Pretty obvious. But I can take that signal and route it back into the xr2206 sig gens for a physical space VCO. I can build this whole thing testing with audio safely. And then switch over to magnetic transmission. We can iron out the number of devices later. Right now I am guaranteed the number of stages. We have come very far in the last 3 weeks. So I choose not to bite the hand that feeds me for I received more than just crumbs but whole loaves and for that I can't embellish enough thanks.
It is all very safe and that is more than I can say about the previous experiments where all the builders have blown themselves up.
Cheers are in order, my friends.
http://www.bose.com/controller;jsessionid=BCkD1DhZ9F10CkvXLQj8zU3s7uN5vIP1oCbk8sJMlT8SKvB2oXVg!643527820!-1915396732?event=VIEW_STATIC_PAGE_EVENT&url=/musicians/index.jsp&linksource=centernav_img_musicians&pageName=/index_2.jsp
--giantkiller. I march on...
OBTW: It is not the circular pathway of the circumference length. But the radial distance where the coppers lies at the resonant distance. Any size coil will work. We are merely catching the rogue wave! Surfs up, dudes. Whooohoo! I posted this over a year ago. What a long strange trip it's been. There's your TPU operation.
Grumpy
Quote"About the collector:  It is three separate coils of multi strand copper wire laid one on top of the other, not
interleaved."
QuoteAs my memory tells me, I originally used three old tube type frequency generators coupled to tube amplifiers It was using this apparatus that enabled me to first strike those magical tones.
Higher frequencies are actually the real catalyst...
Each segment could be fed a different frequency individually and or from a collector section to help perpetuate the oscillation and control.
Start them up one at a time each.
First frequency, then second harmonic component into the second, then the third.  When you eventually strike the cord look out.  You will know what has happened at that point.  In the mean time you can measure a slight output even if you do not strike the exact cord.  Larger collectors have a much greater ability to collect and dissipate more energy then the smaller ones. However, if they turn into a bomb it will not make much difference.  There is no such thing as a small lightning strike
        -Frank Edwards
