Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
0 Members and 49 Guests are viewing this topic.
starcruiser
@GK,
Build the Bendini control circuit, try using that to power the coils. I built it last night and tested it (without the coils) and we get real nice positive going pulses. Tonights test is with my last TPU, top and bottom coils all in series. The center coil will be wired in series as well but used as the feedback. The outter coil (used to be feedback) will be the collector in this setup. Do not use the traditional collectors in this test.
I used the following transistors
NTE 123a
NTE 196
NTE 197
(edited the transistors, had a typo)
The thing I will need to determine is if the outter coil (feedback/collector in this case) will need to be reverse wound.
The next step will be to use a FWBR on its output and then maybe use a large value cap to collect the output.
The cool thing about doing this test is that no major re-work of the TPU is required, The only issue I potentially see is if the current control coils series resistance is sufficient to produce the field and not load the PS or generate a lot of heat in the control coils.
So to summarize my next experiement is the following;
1. Each layer of the TPU's control coils are in series
2. The Top and Bottom control coils are connected in series to increase the resistance and field strength.
3. The middle layer is the feedback to the above mentioned trigger/oscillator circuit.
Did I forget to mention the use of a magnet here???
4. Place a neo magnet on the inside of the TPU next to the middle layer (feedback coil) to initiate the oscillator.
If this experiement goes well and produces interesting results the next step is to build the TPU the right way.
You ask yourself what is the right way?
Well the right way is to use a coil wrapped in a loop (6" dia) using 30ga (maybe 32ga) magnet wire so the total resistance is at least 60 ohms or better (maybe more R?? gotta check this out).
Then wind 2 collectors using 16ga stranded in a loop as well using 24 turns. These are the collectors that can be either in series or parallel. THese wil be placed on the top and bottom of the control/exciter coil.
The Feedback coil will be located in the center of the TPU (small torrid) that will trigger the control/oscillator circuit.
Sounding familar yet?
The Larger TPU's use this design, GK showed this in the last pix he posted showing a cross section of the larger TPU.
Me Thinks we are very close here.
It appears to me that this concept uses an air core transformer with roughly a 28:1 winding ratio (at least with how my last TPU was wound). Also looks very similar to Bendini's battery charger circuit.
GK what do you think of this design/operation?
Regards,
Carl
giantkiller
@starcruiser,
I see the top and bottom controls in series within the segments and the the top and bottom connected in series to impress a squeeze on the middle collector. And all of us that have coils of this wind configuration can jumper in a myriad of paths. So, yes it is good. And the Bedini bemf loop stuck in my mind too. I got a loose association with the stun gun triggered by some part of the TPU as feedback from the Bedini posts about the Little Girl circuit. I was discussing this with MRD10 in Perth and we both agreed that the Bedini was a mechanical version of the TPU. From what you posted, that idea gains more solid ground. The weekend is coming up. Time to really grab some more turf on this issue. I will try your jumps this weekend and fire it with a single gun.
@Grumpy,
yes, I will check out the wire lengths. The backtrack to lamp wire makes project direction changes, temporary or permanent, almost instantaneous. And thanks for the clear post.
@all,
as you can see, patience is king.
@Mannix,
I don't remember seeing this anywhere but maybe the ss in the middle of the ring compression field gives the effect of tube operation. After all there are 2 energies, the EM and RE. Also, could SM have put a spark gap in the TPUs? Like the small ones in the stunguns on the circuit boards, not the external electrode?
--giantkiller. Thanks guys.
Sauron
O great Mister Frequency,
Please tell us about frequency mixing.
Two tones close in frequency generate a beat frequency at the difference of the frequencies, which in this case is subsonic.
For example, a 5000 Hz tone and 5010 Hz tone will produce a subsonic 10 Hz tone.
This is a tone we cannot hear.
But we can feel it  ;D
So, what happens with 3 frequency's??
Maybe two beat frequency's??
And when they come together??
Gee i have to think about that, thanks Mister Frequency.
FatBird
Question for group.
When SM spoke of a Rotating Field, did he mean:
1.  Rotating Back & Forth like a washing machine agitator?
OR
2.  Continuously rotating like water going down a drain?
Each one has its own circuit implications.
Thank you.
