Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
0 Members and 25 Guests are viewing this topic.
innovation_station
innovation_station
FreeEnergy
Quote from: innovation_station on March 27, 2007, 04:06:30 PM
the pics of the test i did last night as i said i would post
is
how are you hooking those wires up exactly?
giantkiller
Here's an additional piece of info:
The GK4 has 18awg bailing/iron wire collectors and 30awg copper controls. By winding at 90 degrees the maximum amount of material interface is met between 2 dissimilar metals.
Jdo300
Quote from: innovation_station on March 27, 2007, 02:56:56 PM
i must start collecting materials but what would reccomend for the caps? i have some small ones and varous uf but my laque of knowalge with caps and transistors is my biggest problem
is
Well, for what we want, my thought is that we want to use a somewhat high value cap (because we want to smack the coil, not oscillate with it). Also, a decent voltage wouldn't be a bad thing.
Since it seems that the coils on the open TPU are farely short, that means that it would require a small value cap (< 1 uF) to resonate with the coil. But again, it depends on the frequency that you pulse the coil with. Though, as a rough guess (based on my personal experiments alone), I always use a 1000 uF electrolytic cap that's rated for 100V. They are small and can be found in power supplies (actually the power supply caps hold more voltage). Plus, if you look at the caps in the 17 inch TPU, you can tell that they are electrolytic also.
BTW, thought I would share with you all a simple experiment I did recently with my 555 pulse circuit, the aforementioned cap, and a 1:1 toroidal transformer. First, I had the cap continuously charged from my 20V 500mA DC power supply. From there, the cap was connected through a MOSFET into the primary side of my transformer. I used my 555 circuit to switch on and off the MOSFET which dumped the cap through the transformer. The secondary side of the transformer was connected through a bridge recrifier to a high voltage cap which my DMM was measuring the voltage on.
I noticed that when I tuned the frequency of the 555 timer just right, I got about 100-200V on the cap. But after I began to play with the duty cycle, thats when the fun started. The smaller the duty cycle on my square wave, the higher and higher the voltage on the secondary would climb. At one point, I managed to get it up as high as 400V+! Keep in mind that this was a weenie little 1:1 transformer not a step up transformer. The key to this was simply the on time of the wave! Also, I noticed that the steeper the rise and fall times of the wave the better the results as well. This is consistent with what Tesla observed.
So the faster we shut the switch on and off, the more radiant energy we get.
Oh, one more thing I should mention... The shorter rise times allowed my cap to stay charged to the same voltage without using much input current to maintain it... So in other words, the shorter the pulses, the less current you need to replenish your cap... Which means that you can take some of the output and use it to top off the cap without needing to keep it tied to a power supply.
God Bless,
Jason O
P.S. Caps also like high voltage spikes :-).
